Boosted_162 wrote:
Oh and one other kinda random question, does having a long hose on a mechanical boost gauge affect the reading?
Bazda wrote:I can get you the braided teflon inner line for the oil pressure gauge.
Its what I run and never had a single leak as they are the aeroquip fittings.
Harlet wrote:Bazda wrote:I can get you the braided teflon inner line for the oil pressure gauge.
You're lucky, the one I got for my turbo leaked like a sieve and caught fire. Cost over $100 to get as well.
iOnic wrote:It was teflon inner with steel braid and was made by Enzed. Wasn't crimped properly that's why it leaked. Don't get monkeys to make oil lines - it can end very very badly.
As for the gauge, +1 to what Akane said lol
iOnic wrote:It was an Aeroquip braided hose and was crimped to a -4AN fitting. Fitting was screwed into the turbo.
eg:
http://img.alibaba.com/photo/237147187/braided_hose.jpg
The leak was between the hose and the fitting. How are your Aeroquip braided lines attached to the fittings that screw into the turbo? Not sure I completely understand how they "all screw together".
Malcolm wrote:iOnic wrote:It was an Aeroquip braided hose and was crimped to a -4AN fitting. Fitting was screwed into the turbo.
eg:
There's a barb on the back end of the fitting, then a nut tightens over the top to clamp it down tightly. Most braided hoses use in cars use this method, have a look at some fittings websites and you'll see what it looks like.
Might I add, -4 for an oil pressure gauge? Seems a bit overkill
Boosted_162 wrote:Thanks all for your help, sounds like more hassle than its worth. Will turn them down and track down some electric ones
Malcolm wrote:I would be amazed if the difference in response was measurable, the volume needed to be transfered to go from min to max on an oil pressure gauge must be something in the order of 5-10ml, if that.
Bazda wrote:Those lines you used look just like the hoses on my washing machine.
If they are seriously those lines = Fail.
Malcolm wrote:Might I add, -4 for an oil pressure gauge? Seems a bit overkill
iOnic wrote:Bazda wrote:Those lines you used look just like the hoses on my washing machine.
Nah that was just an example to show you what I meant by hose/fittingThose aren't even oil feed lines for a turbo so they're definitely not what was used
What you posted is exactly what we had
Dunno how it leaked.
-4 wasn't for the oil pressure gauge, it was for the turbo oil feed - I use electronic gaugesI like oil to stay in engine bays not in interiors
