sergei wrote:How one would deal with P/S fluid spilling? It was at full when I started but not overfilled, the cap was on properly (obviously it is breathing type).
MAGN1T wrote:When the seals in the rack start leaking , the fluid goes into the boots. You then top up the res, drive the car, park it up and the fluid from the boots goes back to the res.
As for the other prob, waterpumps can only cavitate when the cooling system is full of bubbles. Any noise from it is probably rusty bearings, probably caused by the seal thats failed due to too much pressure in the cooling system that's been topped up with water instead of antifreeze because the headgasket has failed.
No, nothing to worry about. Just keep driving it.
Steve
iOnic wrote:MAGN1T wrote:the headgasket has failed.
Steve
If I had $1 for every time I've seen you say this...![]()
MAGN1T wrote:iOnic wrote:MAGN1T wrote:the headgasket has failed.
Steve
Pick a part has them all nicely lined up in rows.
Trouble is kids who don't know how to diagnose a pretty simple and common problem.
Steve
fivebob wrote:sergei wrote:Brand new radiator.
Toyota or aftermarket?
If aftermarket which brand?
sergei wrote:
Ok, the steering rack does not leak, boots dry. Never had the spill problem on normal road, only on race track.
sergei wrote:It is aftermarket OEM replacement (plastic tanks), bought locally, core and tanks looks exactly like original (even inside, looking through filler). The only catch that it is for an auto (got cooling pipe inside for trans cooler, which is not hooked up), original had top tank split at the time, so I needed replacement ASAP.
fivebob wrote:sergei wrote:It is aftermarket OEM replacement (plastic tanks), bought locally, core and tanks looks exactly like original (even inside, looking through filler). The only catch that it is for an auto (got cooling pipe inside for trans cooler, which is not hooked up), original had top tank split at the time, so I needed replacement ASAP.
At a guess I'd say that it's more than likely that if you measured the pressure drop across the core it would be higher than the genuine Toyota radiator. Whether that's due to a difference in design or material used, or if the auto trans cooler just adds a bit too much restriction would be hard to say.
