20v 4AGE oil pressure
Postby 1I1 » Wed Feb 10, 2010 8:56 am
Noticed yesterday on way home from work my oil pressure wasn't as high as it normally is. When rev'd it was getting to 500kPA (72psi) and at idle it was as low as 160kPA (23ish psi)
Should i just ignore the damn gauges or do these sound about right for 4AGE's?
These were both with oil temp sitting at 110degrees C.
Normally i would see 600kPa (87psi) and 180-190kPa (26-27psi) respectively. I let the car cool down and with the oil at 85 degrees it was a little higher at idle and when rev'd it was getting upto 550kPa..... Yes i understand hoter oil=thiner oil
EDIT: my bad, forgot to mention oil being used is 10w-40
TRD Clicky >>Here
1I1
Postby sergei » Wed Feb 10, 2010 9:19 am
Well, during the course of running between oil changes oil will deteriorate and reduce its viscosity, as well as being diluted by unburned petrol. Perhaps it is due to oil change? Although the it could be due to semi-stuck pcv valve supplying more vacuum in crank case (thus reducing relative oil pressure reading). Or the atmospheric end (second tube that normally goes to inlet pipe) of the PCV system is blocked...
Postby 1I1 » Wed Feb 10, 2010 9:37 am
Ah yes oil change, thats getting done this weekend.
It's got a pretty new PCV and its set up with catch can (pcv and breather at end of rocker cover breathe only into the catch can)
TRD Clicky >>Here
1I1
Postby cat007 » Wed Feb 10, 2010 10:22 am
23PSI at idle is heaps
Well maybe not for a 4age - but I'm pretty sure I see about 14psi at idle...
Postby Mr Revhead » Wed Feb 10, 2010 10:41 am
What kind of driving was this? 110 while not nessicarily too high, is getting to the point where you don't really want it much higher.
Postby 1I1 » Wed Feb 10, 2010 11:00 am
Oh it's been higher.... :D Got to 135 once :oops:
Last night it was mainly driving at 100k with a two full runs through 2nd gear while getting up to 100k (and about 20km total driving)
TRD Clicky >>Here
1I1
Postby Mr Revhead » Wed Feb 10, 2010 11:03 am
Lol, it's not too high, but if you were getting that high just tootling around town i'd be worried!
Postby 1I1 » Wed Feb 10, 2010 11:16 am
Round town nanering (spl?) it, temp gets to 85-95 tops
TRD Clicky >>Here
1I1
Postby Mr Revhead » Wed Feb 10, 2010 11:17 am
wouldn't be worried about that at all.
Postby 1I1 » Wed Feb 10, 2010 11:25 am
More worried about the fact the oil pressure is sitting a little lower than normal. Will try new filter and oil to see if that is the cause (due anyway)
TRD Clicky >>Here
1I1
Postby Mr Revhead » Wed Feb 10, 2010 11:26 am
Yeah is someone mentioned above if it's due it could be down a few psi
