BZG Wagon wrote: I hear getting snapped bolts / studs out is a mish
did anyone helicoil a new thread in?
An aircraft engineer contact suggested easy-outs are the worst method for removing these.
Mr Revhead wrote:yeah they do, it's called a new turbo.
getting an extra lug added and having it machined flat again would work.
The new turbo for them has the extra lug
its a matte rof when, not if they will do it. btw the facelift turbo has the extra lug
BZG Wagon wrote:3) Should I replace all the manifold bolts, or just the broken one(s). I was told by Toyota they tend to weaken & snap due to the weight of the turbo on one side.
fivebob wrote:BZG Wagon wrote:3) Should I replace all the manifold bolts, or just the broken one(s). I was told by Toyota they tend to weaken & snap due to the weight of the turbo on one side.
Take a note of the person that told you that and never listen to them again
evil_si wrote:replace the gasket,
dont use silicon or sealant
replace all the studs / bolts
BZG Wagon wrote:evil_si wrote:replace the gasket,
Sweet - thanks for the heads up.
I'll call the local toyota dealership and order the parts tomorrow.
sergei wrote:IF you are talking about albany toyota, after the list you described, the only way I would be contacting them is with that list of fails sent to head office as a complaint, and the reason why they lost business.
Also if you talk to their parts department they will rip you off.
Talk to Mark from sponsor section.
cat007 wrote:I'm also about to do this to my partners car.
Maybe a group buy (of two hehe) is in order?
cat007 wrote:How many studs/bolts nuts would one need?
cat007 wrote:What about the gasket between exhaust housing and down pipe?
