i NEED SETUP LINK FOR THE SILVERTOP
Postby lee90 » Sat Feb 13, 2010 1:41 pm
Hi guys i really need help to find the link about 4age silvertop engine.
the the moment I am doing the cambelt and I need to find out how to put together.
lee90
Postby Burning Angel » Sat Feb 13, 2010 2:18 pm
Its pretty simple really
1:Pull tensioner outwards and lock in place by tightening bolt.
2: line up all pulleys with their marks
3:Run the belt around the pulleys making sure its tight along the side without the tensioner(exhaust side).
4: Release tensioner to tension belt and tighten both tensioner bolts.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Dell'Orto » Sat Feb 13, 2010 2:43 pm
5. Rotate the crank a couple of times to ensure timing is correct
6. Swear and curse cause its not :lol:
7. Repeat
Postby Bling » Sat Feb 13, 2010 9:04 pm
8. Decide you had better find the manual before starting the cambelt replacement.... oh wait...
9. Put the 4age in the corner and chuck a 4k in, its just less work.
10. ????
11. Profit.
Postby frost » Sat Feb 13, 2010 9:38 pm
BZG|Bling wrote:8. Decide you had better find the manual before starting the cambelt replacement.... oh wait...
10. adjust you're day to compensate for the slowness that follows.
11. Profit.
