hey guys this is a wee project of mine
after running the bottom end due to a lack of oil (turbo failed up the bush)
I priced up the rebuild parts, forged pistons, rods ect and I were up to 2K before I put a spanner on it, and its still old tech
so I found a st215 auto motor 130ks for 1.2k
the motor bolts it fine, exhuast is a bit different and the st185 alt needs the threaded boss drilled out so the 215 bolt will go through it
also the bigger inter cooler hits the bonnet slightly
wiring wasnt so easy, stripping the st185 ecu loom out of the car loom wasnt much fun
the auto st215 loom is very basic hardly anything needed to be taken out
it starts and runs fine, but idles very low once its hot, dont ask me what it idles at as the rev counter signals are different
theres no air leaks and I assume the fuel pressure is correct
these motors are a beast pulls harder off boost than any other 3s ive driven
I dont know why people bother with the gen 2's
thanks
Jeremy
also give crispy02 sh@t untill he gets his damn ae86 going!!!!!
