Lateral thinking... large ali cylinder with cap at top...
Postby RedMist » Tue Feb 16, 2010 8:28 pm
Need something to contain 5-7 liters of water for water injection in my offroad race car. As the car is subject to random and excessive G forces I want to run a verticle cylinder with a cap at the top. Rather than fabricate something custom I wondered if anyone could think of something suitable that I could modify for my needs.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby gasman » Tue Feb 16, 2010 8:36 pm
5-7 1L aliminum water bottles?
"What can possibly go wrong?"
gasman
Postby BigDon » Tue Feb 16, 2010 9:43 pm
What about a stubby ali scuba tank? Might be a little HD for your app though.
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby Dragger_Dan » Tue Feb 16, 2010 9:48 pm
Something like a medical oxygen cylinder? I'm not too sure how heavy they are when empty tho.
Dragger_Dan
Postby soopachargen » Tue Feb 16, 2010 10:47 pm
dont want to waste too much space here... but i vote for a keg :P
When in doubt, down and out.
soopachargen
Postby soopachargen » Tue Feb 16, 2010 10:49 pm
on a serious note does it have to be ali? what about something like PVC pipe in a nice strong grade with the ends capped?
soopachargen
Postby stolic » Wed Feb 17, 2010 8:32 am
If it doesn't need to be ali - I've seen some rather tidy setups that used the plastic fuel tanks that are used for outboard boat motors. you can get them in a range of sizes from about 10l to 100l some even have simple level gauge, and cos they are made to hold fuel and not go all "x-splody" I would assume they are pretty tough.
or if you want ali, just find some ali pipe and cap the ends
or link 7 D1 spec catch cans together 8)
stolic
Postby gasman » Wed Feb 17, 2010 9:55 am
stolic wrote:If it doesn't need to be ali - I've seen some rather tidy setups that used the plastic fuel tanks that are used for outboard boat motors. you can get them in a range of sizes from about 10l to 100l some even have simple level gauge, and cos they are made to hold fuel and not go all "x-splody" I would assume they are pretty tough.
those d1 spec cans arent 1L each, they are less than 1L from memory
gasman
Postby stolic » Wed Feb 17, 2010 2:11 pm
oopps did I forget to use sarcastic font again :roll:
tho if you read the first post properly, he states he needs 5-7L so even 700ml per unit would be about 5L, but @$80 each on TM getting something custom made would be cheaper ( and cleaner IMO )
sorry for your confusion :wink:
stolic
Postby Santa'sBoostinSleigh » Wed Feb 17, 2010 3:03 pm
PVC piping with glued end caps would probably be cheapest/easiest.
just choose diameter sized pipe to suit space limitations
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Adoom » Wed Feb 17, 2010 4:05 pm
I used a cereal box for my water tank :D Errrr, a plastic one that is.
PVC pipe sounds like a good idea though. How will you tell if it needs filling? Unless you have a float/reed-switch like mine.
Adoom
Postby soopachargen » Wed Feb 17, 2010 4:28 pm
clear plastic level tube run beside it?? or see how wet your weetbix get
soopachargen
Postby d1 mule » Wed Feb 17, 2010 4:49 pm
old 1gp coffee machine boiler?? generaly brass tho
d1 mule
Postby allencr » Thu Feb 18, 2010 1:24 pm
Frame tube/s & roll cage
allencr
Postby RedMist » Thu Feb 18, 2010 3:04 pm
Cheers Gents.
Frame tubes, regulated out...
Plastic serial box? Was hoping for a screw top lid (its right by my right elbow becide the sequential shifter). I'm not keen on getting wet!
PVC piping. Would get expensive by the time I add fittings, cap... and it would need to take rock impact without shattering. (hence why I have a thick coating of blubber!)
Pressure tanks will probably be too heavy. Certainly sturdy enough for the environment..
Plastic fuel can... was thinking that but given high lateral G's, well G's all over the place actually, I was hoping to keep it as verticle as possible. As in tube like. Makes it harder to get the pickup dry.
gasman- 5-7 ali water bottles??? WOULD BE BRILLIANT! Where the hell do I get one/two?
RedMist
Postby jakesae101 » Thu Feb 18, 2010 3:18 pm
ive seen them at the warehouse before for a few dollars
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby mjrstar » Thu Feb 18, 2010 3:25 pm
Maybe an old 4.5 kg fire extinguisher? Should be cheap enough and the one here in my office has a threaded fitting on the top of it.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby cedwards » Fri Feb 19, 2010 8:06 am
have a squiz at you local Air con reconditioner workshop. I've seen some pretty thin walled disposable gas tanks of about 5-10 litres in bins outside which may be perfect? Guessing it's what they buy the aircon gas in for recharging. Not sure on what material it is though.. May end up rusting.
cedwards
