Radiator Fan staying on.
Postby TRD_ZERO » Fri Feb 19, 2010 5:19 pm
When i turn the ignition on my radiator fan goes on. What is going on? I just cut the old plug off and wired the new fan onto that. Sensors bung?
Previous:
TRD_ZERO
Postby gasman » Fri Feb 19, 2010 5:38 pm
did you rip your old thermo switch off or rip out your aircon?
"What can possibly go wrong?"
gasman
Postby iOnic » Fri Feb 19, 2010 5:39 pm
Bung sensor/damaged wiring to sensor
Postby pc » Fri Feb 19, 2010 6:25 pm
aircon removed?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby TRD_ZERO » Fri Feb 19, 2010 9:47 pm
Yeah i removed the aircon.
Previous:
TRD_ZERO
Postby gasman » Fri Feb 19, 2010 9:53 pm
on ae92's with aircon when you unplug the aircon fan it opens up the thermo switch circuit and turns on tha fans all the time. on non air coned versions theres a shortcircuit plug that jumps the plug completing the circuit.
just join those two wires together or grab one of those jumps and plug it in.
gasman
Postby TRD_ZERO » Sat Feb 20, 2010 10:47 am
So just join the two wires of the aircon fan plug and that will sort it? Which two wires do i join?
Previous:
TRD_ZERO
Postby blindnz » Sat Feb 20, 2010 12:55 pm
I pulled the aircon out of my ae92 trueno, no problems with the radiator fan like this.
blindnz
Postby themaleman » Sat Feb 20, 2010 11:15 pm
my ae92 dose this, what whires do u join? from memory the plug going into the ac pump had more than 2 wires
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby gasman » Sun Feb 21, 2010 12:02 am
its not actually the plug that goes to the pump. its the one that goes to the ac pressure switch.
on ae92's its located near the fuse box in the engine bay and the wires are light green.
gasman
Postby Crampy » Sun Feb 21, 2010 11:14 am
Hmmm, that's damn handy to know. Cheers for the info.
Crampy
Postby themaleman » Sun Feb 21, 2010 11:21 am
mint cheers for that!, so that will stop the fan running constantaly, and only switch on when needed?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby molex » Sun Feb 21, 2010 11:59 am
Correct, fan with function as normal with those two pins joined.
Common story on EP82/EP91/AE92/Virtually everything else made in the 90's.
molex
Postby B1NZ » Sun Feb 21, 2010 8:58 pm
Wicked, my race car fault is now fixed, thanks all :-)
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby AceSniper » Sun Feb 21, 2010 9:45 pm
on a 20v loom its two light green wires on the a/c pressure switch that sits below the coil join them up and its sorted.
AceSniper
Postby Santa'sBoostinSleigh » Mon Feb 22, 2010 12:23 am
mines had a switch installed so my radiator fan is either 'ON' or in 'AUTO' mode (ie normal)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby cat007 » Mon Feb 22, 2010 5:57 pm
Mines running as soon as the engine starts. Even when cold
oh wait - viscous fan ;) hehe
Postby krock » Fri Aug 13, 2010 6:07 pm
AceSniper wrote:on a 20v loom its two light green wires on the a/c pressure switch that sits below the coil join them up and its sorted.
can anyone tell me is the a/c pressure switch got a plug with 4 wires into it which attaches to one of those aluminum pipes(a/c pipe maybe?), and is below the ignition coil?
my a/c has been removed and radiator fan stays on all the time. but i just cut those two green wires(on the aforementioned plug) and tried them together and fan stayed on...?
krock
Users browsing this forum: Google [Bot] and 24 guests
