first gear rev limiter???
Postby Tha_INS » Sun Feb 21, 2010 10:32 pm
Hi didnt have much luck on primera forums with this question so here goes...
I test drove a Pulsar GTI(sr18de) the other day and for some reason it wouldn't let me rev past 6000rpm in first gear. Tried second and it revved sweet till redline just seems not to let me do it in first...
Has anyone ever had this prob with any car? How can it be solved?
Cheers if anyone can shed some light on this...
Tha_INS
Postby Adamal » Sun Feb 21, 2010 10:57 pm
Was it an auto with it locked into either of the gears?
Postby Tha_INS » Mon Feb 22, 2010 12:14 am
nah manual....me and a mate both tried and its like hitting a rev limiter it just keeps bouncing off at around 6k when redline is at 7.5
Tha_INS
Postby Alex B » Mon Feb 22, 2010 12:28 am
They do that, my mate had a VZ-R that would do the same in neutral or if you had the AC on and possibly if the car was cold. Its a protection thing as far as I can tell.
My ITR won't vtec when its cold either.
Postby iOnic » Mon Feb 22, 2010 1:00 am
That's not normal. A GTI should go to redline in every gear regardless of engine temp (not that it's a good idea to try it out on a cold engine). Something's definitely wrong there. Does it do it in neutral? How about in first gear but with foot on the clutch and just free revving? What did the owner say about it? Check for ECU fault codes to start with.
VTEC/VVL is a different thing altogether. The ECU doesn't engage the system unless certain conditions are met (engine up to operating temp, oil pressure within certain range, throttle position over a certain amount, vehicle speed etc etc).
The engine will still rev to redline without VTEC/Neo-VVL - it just won't switch cam profiles. This guy's problem is that it's physically refusing to rev over a certain point like it has a lower rev limiter in 1st gear or launch control.
Postby Adamal » Mon Feb 22, 2010 1:03 am
Alex B wrote:Its a protection thing as far as I can tell.
Wouldn't surprise me. Higher gearing means less possibility of damage through possible valve bouncing.
Re: first gear rev limiter???
Postby Leon » Mon Feb 22, 2010 7:44 am
Tha_INS wrote:I test drove a Pulsar GTI(sr18de)
Interesting. N14 or N15 Pulsar?
Postby Malcolm » Mon Feb 22, 2010 8:35 am
Adamal wrote:Higher gearing means less possibility of damage through possible valve bouncing.
...really?
Postby cat007 » Mon Feb 22, 2010 9:11 am
...really?
YES! :lol: :lol:
Postby sergei » Mon Feb 22, 2010 9:51 am
Lower limiter is very common on low speed.
Nothing to do with gear, as ECU can only guess what gear it is in (of course newer cars are different story).
For example even AE101 will have lower limiter if there is no signal from speed sensor. Various cars will have it as low as 4000rpm if car is not moving.
Postby B_giB » Mon Feb 22, 2010 10:17 am
I drove a honda legend V6 auto that wouldn't redline in 1st gear, If it could get to redline the car speed would have been 70kmh if I remember correctly.
Can't remember what revs it was but its max speed in 1st was 50kmh, Maybe similar thing?
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Tha_INS » Mon Feb 22, 2010 10:33 am
it was an n15....first n15 ive ever driven....ive driven heaps of n14s and have never had problems with the earlier model.....
didnt try it in neutral or with the clutch in.....car was warmed up and owner just said she wasn;t aware of it
Tha_INS
Postby rolla_fxgt » Mon Feb 22, 2010 11:53 am
A similar thing happened to me yesterday. I pulled out to overtake, and hit 9000rpm in 2nd (I thought I was in 3rd when I pulled out). I thought ae101's were supposed to rev cut at 8,000.
When I've free revved it in the past, in neutral its hit rev cut/bounce at 7,500-8,000
rolla_fxgt
Postby iOnic » Mon Feb 22, 2010 12:12 pm
Tha_INS wrote:it was an n15....first n15 ive ever driven....ive driven heaps of n14s and have never had problems with the earlier model.....
Yep N14's definitely don't do it and the 1 N15 I've driven didn't do it either. I'd say there's something wrong with that one.
Postby Tha_INS » Mon Feb 22, 2010 12:43 pm
Yes thats what I thought.....was jusy hoping someone had a quick fix for it since it drives pretty well apart from that one problem
Tha_INS
Postby 79rolla » Mon Feb 22, 2010 2:43 pm
i have had my brothers gti bouncing off the red-line on gravel in first... :lol:
past: AE82 FXGT
79rolla
