Mazda Issues
Mazda Issues
Postby ee904age » Tue Feb 23, 2010 8:24 pm
Not Toyota related, but the mrs has a 94 Familia with a 1500 sohc carb motor in it. It's idling quite high (1200-1300rpm) and im assuming its running rich as hell, because its using heaps of gas (300km /40l) and the exhaust is full of black soot. I dont know much about these motors but have recently replaced plugs, air cleaner, fuel filter and done an oil/filter change and its made no difference. Short of taking it to a garage with a gas analyzer, is there anything I can do to try fix this?
Any ideas??
Thanks in advance,
Shay.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby strx7 » Tue Feb 23, 2010 9:06 pm
is it carbed or Centre Point Injected? I'm guessing most likely that later and that is where the problem lies
Postby sergei » Tue Feb 23, 2010 9:36 pm
I am not sure if it applies to your car, but some of the single point injections units incorporate a hotwire AFM into the throttle body housing. You might need to give it a clean with carb cleaner.
Postby matt dunn » Tue Feb 23, 2010 10:35 pm
sergei wrote:I am not sure if it applies to your car, but some of the single point injections units incorporate a hotwire AFM into the throttle body housing. You might need to give it a clean with carb cleaner.
Nissan models have that are are very bad for broken connection inside the unit from the AFM board to the plug.
