Designing a basic circuit board
Postby nz_climber » Tue Feb 23, 2010 7:35 pm
All you want to do is a simple Analog to Digital Converter, these come in a single chip with a built in LCD display driver. Like the ICL7106 or similar (see the link below gives all the information and details)
http://www.intersil.com/products/deviceinfo.asp?pn=ICL7106
They are really cheap, all you need is that chip a LCD display, a few resistors, caps and 2 pots etc to set up the circuit, build it all on a small section of prototype PCB.
No programming required.
Edit:
Just searched Farnell electronics
ICL7106 Chip: $5:11
nz_climber
Postby Adoom » Tue Feb 23, 2010 8:28 pm
fivebob wrote:1 x Arduino Prototype Board $US18.99
1 x 16x2 Serial LCD $US14.99
1 x Sensor Shield $US6.99 - not really necessary, just make it easier to wire up.
Postage $US11.00
Total $US51.99
~$NZ75
Add a box to house it, a couple of resistors and some wire should cost under $90.
I bought my Arduino stuff from http://www.mindkits.co.nz/
WAY easy to use.
They have a prototype board here http://www.mindkits.co.nz/_product_3624 ... Shield_Kit
$10 freight though.
Stuff arrives in a couple of days.
Every time I see stuff I want thats way cheaper in the US, the freight almost always makes it cost the same or more than if I bought it in NZ........
How long will it take to get here if the freight is only $11?
Adoom
Postby Adoom » Tue Feb 23, 2010 8:32 pm
Hang on! your first link isn't a prototype board!? Its an Arduino. $54.90 from MindKits.....or anywhere else in NZ
Adoom
Postby sergei » Tue Feb 23, 2010 9:28 pm
Postage $US11.00
Total $US51.99
~$NZ75
WAY easy to use.
$10 freight though.
Man this is awesome, it looks like I was doing it hard way.
Postby fivebob » Tue Feb 23, 2010 9:42 pm
Adoom wrote:I bought my Arduino stuff from http://www.mindkits.co.nz/
That's where I bought my first one from too, then I started looking on EBay, way cheaper, I got a Mega1280 for $US33.50, and they're over $100 in NZ, (even found a source in China that sells them for around $US10, but that's in lots of 100). Most of it is made in China rather than the genuine Arduino stuff that's made in Italy. That said I haven't had any issues with the stuff I've bought.
About 5-10 days, it's shipped from Hong Kong by registered airmail post.
Postby fivebob » Tue Feb 23, 2010 9:44 pm
Adoom wrote:Hang on! your first link isn't a prototype board!? Its an Arduino. $54.90 from MindKits.....or anywhere else in NZ
Technically it's known as a prototype board. You're supposed to use it to design the circuits then make you own PCB, but why bother when it's so cheap.
Postby pidge » Tue Feb 23, 2010 10:15 pm
How about a 3 1/2 digit meter?
only catach is they measure 0-200mv, or 0-2V with the correct divider network.
http://www.jaycar.co.nz/productView.asp?ID=QP5570
http://www.jaycar.co.nz/productView.asp?ID=QP5580
http://www.jaycar.co.nz/productView.asp?ID=QP5585
pidge
Postby ChaosAD » Wed Feb 24, 2010 12:05 pm
Or for the same price you could buy this
http://www.jaycar.co.nz/productView.asp?ID=KC5485
ChaosAD
Postby Adoom » Wed Feb 24, 2010 4:02 pm
So off topic..... did you make anything cool?
Adoom
Postby fivebob » Wed Feb 24, 2010 4:24 pm
Adoom wrote:So off topic..... did you make anything cool?
Not really, the main use I had for it was to take a transponder signal and use it as a lap timer for high speed models. I added some temp, humidity & pressure sensors ,a couple of debounced switches for manual stopwatch input, an onboard real time clock, SD card datalogging, a serial LCD, joystick and buttons to allow for data input and control when it's not connected to a PC. If I can get the windows software finished in time it might get used at this years world champs to replace the old DOS based system.
Apart from that I haven't done anything with it yet, though I have plans to write some code to log data from an ECU and reverse engineer the timing and fuel maps, and possibly to turn it into a scan tool ;)
Postby Adoom » Wed Feb 24, 2010 4:53 pm
Ahhhhh, I'm making a robot/tank/mobilewebcamserver....thing(I don't know what I'm doing :P ). My webcam/webserver is a Beagleboard running Xubuntu. STEEEEEEP learning curve to get that working.
Adoom
Postby cat007 » Wed Feb 24, 2010 4:54 pm
I think I'm going to go with the JayCar kit for $70
Much less hassle than spending $50 on parts and then try and put it together and then code it lol
Thanks for your help everyone :)
Postby ChaosAD » Wed Feb 24, 2010 5:34 pm
Or if you havent already purchased the lc1, for about $70 extra you can get the lc1 and DB gauge together
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Electronics/auction-273163530.htm
ChaosAD
Postby cat007 » Wed Feb 24, 2010 5:45 pm
Yeah. Except I bought the lc1 a while ago. It wasn't that cheap when I bought it lol
