true?no wrote:What to look for 96 Sti WRX
sergei wrote:May I suggest an STI instead? WRXs are generally not slow, but not fast either. STI on other hand go really well.
cogent wrote:With the way certain..cultures..seem to latch onto WRX's, you'd think they actually had some decent level of pull!
Alex B wrote:cogent wrote:With the way certain..cultures..seem to latch onto WRX's, you'd think they actually had some decent level of pull!
Yeah, took the sisters bf one out the other day, stock as a rock. Didn't feel that much quicker than the teg really.
dnalunchie wrote:Alex B wrote:cogent wrote:With the way certain..cultures..seem to latch onto WRX's, you'd think they actually had some decent level of pull!
if you did the same I had done to mine with the retune and headers u would find your even with a stock rex. My mates richie from Jones motoring had a version 8. It was totally stock and couldnt pull away from my old teg.
cogent wrote:sergei wrote:May I suggest an STI instead? WRXs are generally not slow, but not fast either. STI on other hand go really well.
About 2-3 months ago I helped my friend install STi shocks/springs into his WRX wagon. Afterwards, he let me take it for a drive and I could not believe how slow it was. Well, I guess slow is not the right word, but overall it felt pretty weak for a turbo car.
WRX: most over-rated vehicle ever?
~SlideWays~ wrote:Well if you think about it, a WRX has about 170kw at the flywheel...if factory figures are correct.
And with fulltime 4wd sucking up a big chunk of that, lets just say 20% (could be more or less...) that works out to be 136kw at the wheels.
They weigh 1240kgs ...ish
Thats only 109kw per tonne at the wheels.
A good blacktop makes about 100kw's atw and roughly 1000kgs. So not much in it really.
B1NZ wrote:~SlideWays~ wrote:Well if you think about it, a WRX has about 170kw at the flywheel...if factory figures are correct.
But your forgetting the massive amounts of torque a blacktop 4age has as well
I thought WRX's had 160kw at the flywheel, STI's are 205kw? Most stock STI's get about 160-170kw@wheels. But dont take much to get over 200kw@wheels
They arent miles ahead of other performance cars out there, Im sure a DC2 teg would possibly give mine a good run for its money if not beat it, but at least I'm not driving a honda
Users browsing this forum: Majestic-12 [Bot] and 5 guests
