converting to manual steer
Postby jakesae101 » Fri Feb 26, 2010 7:03 pm
how hard is it to do in a ae92 trueno i know i need the rack and universal and the covers but so i need anything else or is it worth keeping power steer my high pressure line is weeping and its a wof fail when i come up for one
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby deaf_rattle » Fri Feb 26, 2010 9:25 pm
just get a new hose made up, it would be cheaper and easier
Postby Mr.Phreak » Fri Feb 26, 2010 9:52 pm
deaf_rattle wrote:just get a new hose made up, it would be cheaper and easier
+1
Mr.Phreak
Postby matt dunn » Fri Feb 26, 2010 10:07 pm
+2
Postby Leon » Fri Feb 26, 2010 10:08 pm
Didn't you used to work for Mossrax, so could in fact possibly even get a decent deal on said hose?
Postby pc » Fri Feb 26, 2010 11:11 pm
Pick-a-Part, or ask Andrew if he still has one on his AE92 trueno wreck.
I've tried manual steering... I say don't do it.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby sergei » Fri Feb 26, 2010 11:38 pm
Pick a part your best and cheapest bet, does not have to be an AE92 exactly.
Postby jakesae101 » Sat Feb 27, 2010 7:56 am
Leon wrote:Didn't you used to work for Mossrax, so could in fact possibly even get a decent deal on said hose?
me and chris arent on speaking terms and yea maybe i will a standard 4age hose wont work i think it has to be a gze one due to the pump possition
jakesae101
Postby Mr Revhead » Sat Feb 27, 2010 8:37 am
Any hydraulic hose place can make a new one from your old one.
Prob be under $100
Postby deaf_rattle » Sat Feb 27, 2010 8:40 am
Mr Revhead wrote:Any hydraulic hose place can make a new one from your old one.
Prob be under $100
you can get special power steering fittings which you can make up at home when used with the appropriate ps hose.
The 2 ends, 2 adapters and length of hose was under $100 and took about 15 mins to make.
Im yet to see if it leaks, but ive been assured that these fittings are the go. (i thought you needed crimp type fittings) but these are designed especially for ps.
Postby gmacrae » Mon Mar 08, 2010 12:21 pm
I removed the PS from my fxgt - love it.
gmacrae
Postby B_giB » Mon Mar 08, 2010 12:31 pm
If you remove p/s you wont pass a WOF from what I understand
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby ATAl » Mon Mar 08, 2010 12:34 pm
You'll need a cert to pass wof if you convert to non power steering, just get a new pipe made, it's the cheapest option.
ATAl
Postby iOnic » Mon Mar 08, 2010 2:23 pm
You won't fail a WOF nor will you need a cert as long as you use all factory parts and don't modify anything. Seems like taking the long way around a small problem though. Just replace the line.
Postby Crampy » Mon Mar 08, 2010 5:10 pm
My car was balls without power steer. PS racks are normally faster too, so going to manual is a step back IMO.
Crampy
