Car seems to drain all water randomly
Postby dnalunchie » Fri Feb 26, 2010 8:09 pm
Ok so here is the deal I own a 1.3 carbed 87 suzuki swift and its doing sumthing random.
Ill be driving along and it will suddenly get SUPER hot and I pull over and check the radiator , empty, check the overflow tank, full, also the hose that comes off the overflow tank looks to be the place where the water is all emptying, or atleast some of it.
So I fill it up again, and BANG 30 mins later, hot again, radiator empty, overflow tank full.
What is going on? Someone has mentioned a head gasket>?
I know the fan is working.
The tank is VERY dirty but seems to flow fine.
Getting sumwhat concerned here.
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby jakesae101 » Fri Feb 26, 2010 8:11 pm
a leak possibly
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby sergei » Fri Feb 26, 2010 8:13 pm
Where is MAGN1T where you need him?? :lol:
Sound like it gasses from BHG are pushing all the water out.
Let it cool fill it up and start it up without cap, add water as normal bubbles come out, wait for thermostat to open, add more water as necessary, if at this stage it is bubling, then it has BHG.
Postby iOnic » Fri Feb 26, 2010 8:24 pm
sergei wrote:Where is MAGN1T where you need him?? :lol:
+1 :lol: Sadly it sounds like BHG like Sergei said.
Postby Dell'Orto » Fri Feb 26, 2010 8:46 pm
C'mon Steve, its your time to shine :lol:
Postby hachiroku3 » Fri Feb 26, 2010 9:16 pm
if it's losing water as fast as you say, i would imagine it would be easy to notice whether it's a blown hg or not. heaps of smoke or milky as oil. firstly, i would check to make sure the radiator cap isnt screwed and just letting the coolant out of the radiator as soon as any pressure builds up inside it.
hachiroku3
Postby frost » Fri Feb 26, 2010 9:46 pm
Dell'Orto wrote:C'mon Steve, its your time to shine :lol:
I F@#%ing LOL
Postby fivebob » Fri Feb 26, 2010 10:32 pm
Probably doesn't want to ruin his perfect record of BHG (mis)diagnosis and actually get it right for a change ;)
Postby evil_si » Fri Feb 26, 2010 10:51 pm
go to an automotive store and grab a teekay head check kit
basically you put some special fluid in its vacuum pump. jam it in the top of radiator and pump it to create a vacuum to draw any combustion gas thru,
if head gasket is blown and pushing gas into water system the fluid changes colour.
evil_si
Postby Burning Angel » Sat Feb 27, 2010 11:52 am
well had a look at the beast 2day and it seems like it is a BHG, bubbles coming out radiator when warm, still blows out about 2L of coolant even with a new Rad cap.
Also starts like a sack now, probly due to drawing water into the cyl when its off.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Burning Angel » Sat Feb 27, 2010 2:17 pm
Yup definitely a BHG
Blown in two places, exhaust side of #1 & #4
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby cat007 » Sat Feb 27, 2010 3:09 pm
good effort!
Hopefully she'll be back on the road in no time :)
Postby Burning Angel » Sat Feb 27, 2010 6:17 pm
cat007 wrote:good effort!
just finished putting it together, goes mint now
also the timing belt was out 1 tooth which explains why it used to be so guttless.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby dnalunchie » Sat Feb 27, 2010 8:52 pm
Would like to thank Laas here (Burning angel)
I went to work, he texts me at like 12, tells me he thinks a BHG and so I ask him if he feels like replacing it, he picks me up from dinner at like 8 tonight, all done.
$&#$% legend
dnalunchie
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
