throttle cable question.
Postby deaf_rattle » Mon Mar 01, 2010 9:59 pm
looking into throttle cable set ups at the moment.
gone ffim on my 7mgte and want to know what people do when switching to a ffim.
The stock set up pulls from the front, where as i want to pull from behind.
any comments/info would be most helpful.
Postby cat007 » Mon Mar 01, 2010 10:14 pm
What did Suze do?
Postby deaf_rattle » Mon Mar 01, 2010 10:15 pm
she ran a different throttle body. 1uz iirc
Postby Dell'Orto » Mon Mar 01, 2010 10:32 pm
Should just be able to swap the throttle wheel around? Unsure as to what you're using
Postby cat007 » Tue Mar 02, 2010 7:50 am
Is there no way you'd change to a 1uz t/b?
Wouldn't it just be easier?
Postby bluemaumau » Tue Mar 02, 2010 8:44 am
i thought youd be using an aftermarket t/b anyway
Postby deaf_rattle » Tue Mar 02, 2010 3:50 pm
dont need a larger t/b so didnt feel the need to replace it when the stock one will do the job.
Postby cat007 » Tue Mar 02, 2010 3:51 pm
deaf_rattle wrote:dont need a larger t/b so didnt feel the need to replace it when the stock one will do the job.
Not saying you need it or not - but wouldn't it make life easier and help if you want more powers later on?
Postby deaf_rattle » Tue Mar 02, 2010 3:53 pm
if i want more power later on ill go aftermarket ecu and tune more out of it.
but really anymore power would be a waste of time in this chassis without alot more time and money spent on sorting out the rear end and tyres.
Postby cat007 » Tue Mar 02, 2010 3:55 pm
deaf_rattle wrote:if i want more power later on ill go aftermarket ecu and tune more out of it.
Fine
Don't go for the rear pulling 1UZ t/b what would end up looking clean and simple and spend hours and hours pondering how you're going to get the 7M one to work and then have some fugly setup that ruins your currently great looking engine bay.
Postby Malcolm » Tue Mar 02, 2010 11:13 pm
I reckon I could figure something out for you, have you got a throttle body assembled? If so I'll have a look next time I'm over, I'm sure there's got to be a relatively easy solution. I assume it needs 2 cables, one to actuate it and then one to the auto?
