Took the car for a squirt after putting the turbo manifold back on and found it to be running real rough once it warmed up.
Found it wasnt running properly on 2 cylinders, pulled out those 2 spark plugs and F#$K ME the end of the spark plugs were completely blown off, all that was left was the metal rod up the centre. Amazing thing was when it was cold it was running sweet!!
With the 4agte Manifold Im using I had to take the CAS out to get the manifold back on, after a bit of trial and error I got the CAS back in the right spot but not before I must have had the engine running massive advance which Im guessing rooted the plugs (platnium nikko denso).
I have done a compression test and everything looks alright there, now my biggest worry is should I just throw some new plugs in it and hope for the best.....or should I be pulling the head off to inspect for piston/valve damage and potentially damage to the turbine??
