matt dunn wrote:I have tried a few various gaskets between the turbo and the exh manifold. None lasted more than a few laps including the expensive genuine nissan one.
My new theroy is it can't blow the gasket if there isn'e one,
so the surfaces were machined flat and bolted together with no gasket and no sealer, straight steel to steel,
and has been the best yet. No leak as such and no problems.
I can understand your theory about the 'cant blow a gasket if it's not there' - BUT, and this is a big BUT, you'd have to get the surfaces so freaken smooth for it to seal properly! The tolerances between the two surfaces would have to be very very fine.
Also what do you mean, 'no leaks as such'? As in no major ones? Or none at all?
