Harlet wrote:Run my EP82 without the charcoal canister for years even had track use and had no issues with the removal of it. Didn't block anything off either.
Rick wrote:All you need is a to put a vent (like the ones below) in place of the charcoal canister its best to vent to the outside of the car not under or in the engine bay, there are a few different types around, some have ball bearings in them in case the car gets inverted etc... and have a flash aresster built into them. I have my one just behind the rear bumper.
jakesae101 wrote:where do you get these from?
Quirky wrote:Is it still okay to have the charcoal canister connected as per usual on a 4ag thats turbo? I would think that the vacuum line will now pressurise the charcoal canister?
Snaps wrote:Quirky wrote:Is it still okay to have the charcoal canister connected as per usual on a 4ag thats turbo? I would think that the vacuum line will now pressurise the charcoal canister?
Which would then pressurise the fuel tank, wouldn't it? (Unless there's a one-way valve in the charcoal canister)
Bazda wrote:Ok i'm a little confused..
Do the charcoal canisters vent pressure from the tank, or do they let the tank suck in air? Or it does both?
I thought that when you open the fuel cap after a long run its sucking air into the fuel tank not venting it out? As the fuel pump is sucking petrol from the tank therefore that space needs to be replaced by air...
cat007 wrote:So I'm still unsure of the outcome of this thread.
I'd like to remove mine - but don't want to just vent to the atmosphere for fear of the gases building up in certain areas and igniting.
Am I being paranoid?
What would a track marshal think of such things?
What do 'race cars' do?
