4age stumble
4age stumble
Postby Boost_4_Life » Sun Mar 07, 2010 4:10 pm
I know there are threads on this but buggered if i could find them...
anyway, wanting opinions/advice. Just put the silvertop back in my starlet after getting some work done on the car. driven it a few times and its been running a bit flat. anyway today tried giving it a decent thrash, and it hesitates at about 3 grand then again at 6. makes $&#$% all power. checked codes, and 21 is up. That is normal for this car, its running no oxy sensor or speed sensor. and before you tell me off for no oxy sensor its been running fine without it for 3 years, its a rally car.
anyway couldnt find any dodgy sensors so checked my ecu for the leaky cap issue. found a tiny amount of residue under one so replaced he ecu with a spare i have here. took it for a squirt and all seems well. nice power and no hesitation.
my question being thus, do the capacitor issue cause the above symptoms or have i inadvertantly temporarily fixed the issue whilst poking around in engine bay?
Its an issue cos a big hesitation in a rally car mid corner on gravel = stink au.
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby Dell'Orto » Sun Mar 07, 2010 4:11 pm
Nah sounds like the ECU is the problem.
Postby .:O4AGTZ:. » Sun Mar 07, 2010 9:36 pm
could be some kind of limp mode. In my GTZ what happened was the supercharger turned off and it was hard to get anything out of it.
The cause was leaky caps. Engine check light would come on and it would do it intermittantly. No codes come up either. Replaced ECU and all was sweet again.
.:O4AGTZ:.
Postby Boost_4_Life » Mon Mar 08, 2010 7:30 am
mmm, drove it again to work this morning and all still seems fine. I'll be giving it a good run before the week is out so I'll report back but fingers crossed...
The rally beast
Boost_4_Life
Postby sergei » Mon Mar 08, 2010 8:59 am
When my ECU leaked its caps it would run rough, occasionally run ok, but get some bad flatspots, and occasionally would not even idle, and leak some other signal to VVT circuit causing VVT to semi-engage permanently.
Postby 96bzg » Mon Mar 08, 2010 2:57 pm
i have preaty much the same problem hesatates at 3000 rpm ive replaced oxy n fixd for a week now its doing it again when i last checkd codes 25 came up ...
96bzg
Postby Boost_4_Life » Mon Mar 15, 2010 7:39 am
well it had the life thrashed out of it at a rallysprint yesterday with no issue at all. went bloody well actually, much better power :)
The rally beast
Boost_4_Life
Postby .:O4AGTZ:. » Mon Mar 15, 2010 3:53 pm
Boost_4_Life wrote:well it had the life thrashed out of it at a rallysprint yesterday with no issue at all. went bloody well actually, much better power :)
which is why I am pretty sure it would be leaky caps in the ecu. It happened to me twice before I got it fixed, and both of these times were completely at random.
.:O4AGTZ:.
