20V BT and ST Cam wheel differences?
Postby matt dunn » Thu Feb 11, 2010 11:14 pm
frost wrote:the dowel is for using silvertop toda cams in a blacktop head with blacktop cam wheels. because toda only make silvertop cams
Yeah I would have to agree with that,
as from what I can tell, the cam wheels are the same and interchange.
Next question is, why do TODA sell a different adjustable cam wheel set for a BT and a ST?
And the ST TODA wheels I have have two different markings on them,
and two numbers with each, a 4 and a 5,
so which one do you line up at TDC?
Postby AE25 » Fri Feb 12, 2010 1:06 am
one would think the belt width between ST and BT is why they have two different pullies. wouldn't want to run an BT belt on a ST pulley... it'd be running off the edge or close to it.
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby matt dunn » Thu Mar 11, 2010 10:06 pm
The question now is why do the ST and the BT run the same cam timing, profile and lift,
but at different timings by 5 deg?
Postby AE25 » Fri Mar 12, 2010 12:33 am
http://club4ag.com/faq_and_tech_pages/4 ... ations.htm
if thats anything to go by. BT intake cam has more lift
E2 & E7 fanatic
AE25
Postby matt dunn » Fri Mar 12, 2010 10:39 pm
AE25 wrote:http://club4ag.com/faq_and_tech_pages/4A-GE_technical_specifications.htm
yes correct the ex is the same but the inlet has a bit more.
