Blacktop Oil Pressure
Postby Petrolhed » Sun Mar 21, 2010 6:18 pm
Tried searching but couldn't find what I wanted.
Does anyone know the maximum pressure that a blacktop should run IF everything is working correctly? The reason I ask is that I have a chance to get an oil pressure gauge at a good price, but it only reads to 100PSI. Will this be enough?
Petrolhed
Postby iOnic » Sun Mar 21, 2010 6:41 pm
Can reach 100psi when cold + revving. Otherwise it's normally around 50-80psi while driving around at operating temp and ~40psi (sometimes less) idling at operating temp
Postby Petrolhed » Sun Mar 21, 2010 8:05 pm
So Second question: Is there a factory mounting point for the sender? Or do i have to get a filter plate?
Petrolhed
Postby sergei » Sun Mar 21, 2010 9:42 pm
Petrolhed wrote:So Second question: Is there a factory mounting point for the sender? Or do i have to get a filter plate?
There is a pressure switch for oil light, that port could be used for sender.
Do not use brass fittings. Use only stainless.
The pressure switch located behind AC bracket.
Postby cat007 » Sun Mar 21, 2010 10:16 pm
sergei wrote:Do not use brass fittings. Use only stainless.
Because the brass is easy to over-tighten/strip and leave small metal shards in the system?
Postby deaf_rattle » Sun Mar 21, 2010 10:25 pm
brass vibrates and breaks.
Postby FANGIN » Mon Mar 22, 2010 8:17 am
iOnic wrote:Can reach 100psi when cold + revving.
You shouldn't be revving it when cold :wink:
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby sergei » Mon Mar 22, 2010 8:54 am
Brass cracks from vibration.
Postby cat007 » Mon Mar 22, 2010 8:57 am
I see. Thanks for that tip guys. I wouldn't have thought of it. But it totally makes sense! *goes hunting for brass fittings on engine and gets them replaced* :)
Postby CAMB01 » Mon Mar 22, 2010 9:32 am
If you get more than 100 psi of oil pressure your oil filter will most likely blow off the side of the motor
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby iOnic » Mon Mar 22, 2010 11:34 am
Was a bit of a "worst case" exaggeration. I've seen 90psi on a Silvertop that one of the munters I went to course with decided to drive (fairly hard) after first start to prove to me that 4AGE's "still goes hard" when cold after I told him VTEC engines don't engage the system under a certain coolant temperature :roll: Some mothers do have them.
Postby 1I1 » Mon Mar 22, 2010 1:28 pm
Seen mine get to roughly 90psi (~600kPa)
TRD Clicky >>Here
1I1
Postby Petrolhed » Mon Mar 22, 2010 9:07 pm
Sweet. Cheers Everyone
Petrolhed
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
