Hi guys,
My brakes don't seem to be disengaging after a stop. It takes a few taps on the pedal and a few pulls on the handbrake to get them to loosen up, so the other night I got home and found that the rear right drum was too hot to touch, where the others were warm!
So I've stripped the rear right drum, cleaned everything (it has newish pads in there, the slave cylinder did have a bit of rusty crap in it, but the seals and internals of the cylinder look fine) and its' still doing it. Bled the brakes twice, no change. If it was the proportioning valve, wouldn't both sides do it? No blockages either.
I don't have much experience with drum brakes, is there something obvious that I'm missing?
Cheers!
