Its running the 1.3 carbied powerhouse too
Any ideas on what to check/replace?
MR2SIK wrote:As in title, my Ford Laser has an intermittent problem where it won't start, 9/10 its fine, then on the odd occassion when you turn the key, nothing. Bought a new battery, and it still does it. Leave it for a couple of hours and its fine, also jump starting it works too.
Its running the 1.3 carbied powerhouse too![]()
3T-Rona wrote:voltage drop between key and starter.
next time it doesnt start put a wire between the battery supply on the starter and the excite terminal, if it starts no worries then u have a voltage drop problem.
fit a starter slave relay.
MR2SIK wrote:3T-Rona wrote:voltage drop between key and starter.
ok n00b question time, where do I find the bloody starter?
