toyotaspeed wrote:Hey guys
I know many of you have the problem with the ae101 gtz power dip after 5500rpm. Tonight i switch to an ae92 map ecu and there is no evidence of the power drop. Stocked with how well this worked, pulls hard to the redline now. So if your sick of the drop hunt down an ae92 ecu well worth it!
True-No-Turbo wrote: but ae92 ecu wont run ae101, been there and tried it?
Rick wrote:True-No-Turbo wrote: but ae92 ecu wont run ae101, been there and tried it?
Whys that?
Quirky wrote:Ohh yea, you have to do a bit of modfying, i think it was only one pin or two pins out of place(?)
Quirky wrote:It works, just make sure both applications are MAP.
