To Gizzmo or not to Gizzmo
Postby eskimo » Thu Mar 25, 2010 6:28 pm
I currently have a Gizzmo cam FC in my AE111 corolla GT. It was in the car at when I got it. Its being used as an AFM
Its causing a few issues & Im wondering weather I remove it and plug the MAP sensor thing back in or leave it in the car and get it tuned correctly.
Reason im thinking of removing it as I dont see much point of having one on a lightly tuned NA engine.
I think the car could do with a tune with or without the FC but if i dont think there is any advantage of actually having in there apart from bling factor 8)
What do you guys think?
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby eskimo » Fri Mar 26, 2010 7:43 pm
Any one think leaving the FC in the car has an advantage when it comes to tunning it?
eskimo
Postby frost » Fri Mar 26, 2010 10:39 pm
it wont if you have stock cams, anything under 260 duration should not need a controller, it only controls when to turn off and on vvt right?
map sensor thing? whats been unplugged? something on the engine or the wiring loom.
Postby iOnic » Sat Mar 27, 2010 7:23 am
Cam FC is Gizzmos's Apexi VAFC. It controls switchover as well as being a normal piggyback fuel controller. I'd say get it tuned properly and see what you think of it then.
Postby mr30%jr » Sat Mar 27, 2010 9:48 am
its a blacktop eh?
your better of just ripping it off if the engines fairly low key, put that map sensor back on....
they are handy if you want to ditch the AFM on silvertops and for turbo engines...
mr30%jr
Postby eskimo » Sat Mar 27, 2010 6:36 pm
Yea its a black top, I was thinking of removing it, getting the car tuned(the air fuel mixtures sorted as it runs a little ritch)
Ill either sell it or just save it for when I get around to building a 4AGTE
eskimo
Postby iOnic » Sat Mar 27, 2010 6:39 pm
How will your car be tuned without it? The stock ECU isn't tunable...
Postby eskimo » Sat Mar 27, 2010 9:48 pm
iOnic wrote:How will your car be tuned without it? The stock ECU isn't tunable...
Yea my bad, should of said. Ill be removing it and seeing what happens to the airfuel mixtures once it running the factory set up, as it currently runs a wee bit ritch
eskimo
Postby ChaosAD » Sun Mar 28, 2010 9:30 am
If you try to tune a blacktop ecu with a piggyback, it will usually just self tune itself back again
ChaosAD
Postby mr30%jr » Sun Mar 28, 2010 11:05 am
they run PERFECT on stock ECU as long as all sesnors are hooked up and map is correctly set.
mr30%jr
Postby frost » Sun Mar 28, 2010 9:21 pm
mr30%jr wrote:they run PERFECT on stock ECU as long as all sesnors are hooked up and map is correctly set.
not true, they run slightly rich from factory,
Postby mr30%jr » Sun Mar 28, 2010 9:31 pm
mine doesnt.
maybe with stock airbox, and cat with stock exhaust :?:
mr30%jr
Postby eskimo » Sun Mar 28, 2010 9:48 pm
This is what i was hoping to get back to by removing it rather than spend coin on dyno time to get the FC set up correctly
eskimo
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
