I need some help with my SRI install.
I have two stray hoses and a part of the MAF which I don't know where to attach to the Weapon R SW SRI.
In Photo A:
You will see at No. 1, I plugged up the side inlet of the SRI pipe with tape for the moment.
I believe 2 and 3 feed into the evaporation unit and its correct so maybe I'm missing a hose from the throttle body which should feed into "1"?
Does anyone know which pipe should feed into "1", or if its ok to keep it blocked off?
For a better look at the Numbers 3 and 4, see Photo B
I'm in East Auckland, would be happy if someone could have a look at it for me. I'd be happy to drive to where you are.[/img]
