smallport 4age dipstick length
Postby panda_dan » Mon Mar 29, 2010 4:07 pm
Team
I need to know the length of the factory smallport 4age dipstick from under the handle (where it sits on the top of the feeder tube) to the tip
Thanks
Danny
panda_dan
Postby blindnz » Mon Mar 29, 2010 5:05 pm
bigport would be good to because i have wrong dipstick in mine and need to work out how far out my oil is.
blindnz
dipstick
Postby panda_dan » Mon Mar 29, 2010 5:10 pm
Yep same situation for me
I have a blacktop one which is considerably longer and the oil reading is an inch over the full mark even thought I know that it has roughly the right amount of oil in the sump for a smallport
So i bought a smallport dipstick from a wrecker down country, he sent it to me, but i think it's the wrong dipstick, too short, because when i do a test dip there's not a spot of oil on the stick
If anyone has a smallport with factory dippy in it, please let me know
panda_dan
Postby Mr Revhead » Mon Mar 29, 2010 7:06 pm
This has come up a couple of times....
so lets make a FAQ
Can people who have whatever engine post here the measurements of the appropriate dipstick.
lets get all 4ages and how about all 3sge/te variants
lets have from under the head (Ie where it seals agaisnt the tube) to the FULL mark.
Please be exact as a coupla mm difference can make a difference.
Postby frost » Mon Mar 29, 2010 7:44 pm
small port 4age from under the stopper to full 292mm. low 315mm
big port 4age from under the stopper to full 239mm. low 262mm
3sgte gen4 caldina under stopper to full 446mm. low 470mm
(i think)
silvertop 20v full 355mm. low 370mm
cos my one is bigger!
e65 bmw 713mm 8O
Postby crispy'86 » Wed Mar 31, 2010 6:50 am
Is there any difference between the bigport and smallport disptick tube length?, saying the dipsticks themselves are different lengths i'd imagine the tubes are different.
crispy'86
Postby pc » Wed Mar 31, 2010 5:44 pm
crispy'86 wrote:Is there any difference between the bigport and smallport disptick tube length?, saying the dipsticks themselves are different lengths i'd imagine the tubes are different.
Yep, i've seen a few. Different dipstick lengths all on the same/similar block with similar sump pan. Tube length is also a vital measurement.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Dippy
Postby panda_dan » Sat Apr 10, 2010 11:33 am
Ok so does anyone know the different lengths of all 4age dipstick tubes ?
Because mine is 220mm and my friend's tube is 80mm and we both have factory 4age smallport engines
panda_dan
Postby Mr Revhead » Sat Apr 10, 2010 11:38 am
80mm?
If in doubt, just drain the oil, put in exactly 3.1 litres and there's your full mark. Give or take 100 or so mls
Postby frost » Sun Apr 11, 2010 1:43 am
3.1??? is it closer to 4liters? i've always had to almost empty the container, to get to full mark,
Postby Bling » Sun Apr 11, 2010 1:51 am
From memory I would go with closer to 3L than 4L by what i've had left in bottle. That being said, I know for a fact you can get 7L into a 4afe :x Not my doing I swear.
If blacktop measurement is needed for the FAQ I can have a look, as well as 4afe of same year.
Postby frost » Sun Apr 11, 2010 4:02 am
ok maybe not empty but only about 150ml left,
is there a difference between fwd and rwd sump volume? i don't think there is, smallport with rwd sump btw,
Postby Mr Revhead » Sun Apr 11, 2010 9:25 am
3.2-3.4 litres with filter change for fwd.
Not actually sure I've ever changed a rwd one
Postby blindnz » Sun Apr 11, 2010 6:11 pm
depending on if you do the filter or not too.
blindnz
Users browsing this forum: Google [Bot] and 31 guests
