4agze blowing oil out of catch can?
Postby D0DGEE » Tue Apr 06, 2010 8:57 am
just got my corolla going again and did some skids in it and there was heaps of oil blown out of my catch can. got a -10 hose from each rocket cover going to a catch can with a divider in the middle so it dont blow the oil straight out but it is. running 5-30w oil is that to light for the motor or are my rings going which is causing it to blow by and out the breather?
D0DGEE
Postby tsoob » Tue Apr 06, 2010 10:51 am
does the thing blow any smoke?
check if the hoses are pressurising.
or do a leak down test
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Re: 4agze blowing oil out of catch can?
Postby allencr » Tue Apr 06, 2010 3:51 pm
D0DGEE wrote:did some skids in it
Is this the first time its done 'some skids'(WEITFTM) with this 'rocket cover' :D setup? If not, then something recent has worn/broken and has caused a lot more blowby. New rings, and/or better head drainage, clean up its ports.
Yes, the thinner oil means more is going to flow & be up top, but not enough to make a big difference by going thicker.
allencr
Postby Quirky » Tue Apr 06, 2010 6:07 pm
5-30 is oil is ok, its a little thin.
I was running 5-30 and had plenty of blow by, changed to 10-40 and it was much much better.
Mileage pending
Hello There
Quirky
Postby whynot » Tue Apr 06, 2010 7:06 pm
If it's a 16valve head it could be that you flooded the rocker covers with oil from the sustained high rpm. done that before and thought I had killed my motor real good.
whynot
Postby D0DGEE » Tue Apr 06, 2010 10:33 pm
blows no smoke. motor prob needs a freshen up its was rebuild about 6 years ago but it gets a hiding when it does go but still goes hard. was told the oil to light so going to change that t o10-60w and see if that helps. its got a red top head on it and i bunged up the return at the back of the head up.
D0DGEE
Postby mr30%jr » Tue Apr 06, 2010 10:51 pm
hm wonder why they put that return pipe there on the revised model.......................hmmmmmmmm nooooo i cant think why :lol:
for that very reason
mr30%jr
Postby whynot » Tue Apr 06, 2010 10:59 pm
that return pipe would have stopped me doing a disappearing act after 30 seconds of passing lane at 7500rpm. it's possible you might get less smoke and oil usage just by trying different brands of oil with the same viscosity rating, some motors are just fussy like that.
whynot
Postby cat007 » Wed Apr 07, 2010 12:52 am
whynot wrote:that return pipe would have stopped me doing a disappearing act after 30 seconds of passing lane at 7500rpm. it's possible you might get less smoke and oil usage just by trying different brands of oil with the same viscosity rating, some motors are just fussy like that.
Holy hell!! :o
How long and steep was the passing lane that you were sitting at 7,500rpm for 30 seconds??
tehehee :lol: :lol:
Postby whynot » Wed Apr 07, 2010 6:46 pm
was been a wee bit hard on it with a full car load of people, That motor is still going though with 260.000ks...fun times were had :D
whynot
