bumper mesh
bumper mesh
Postby tsoob » Wed Apr 07, 2010 1:11 pm
What would you recommend using to hold it in?
The bumper is fiberglass so i don't want screw it in.
Maybe something like sellys liquid nails?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Dell'Orto » Wed Apr 07, 2010 1:17 pm
Yup, or bog. Anything sticky that sets strong will be fine
Re: bumper mesh
Postby cat007 » Wed Apr 07, 2010 1:42 pm
tsoob wrote:What would you recommend using to hold it in?
Where did you buy the mesh from?
Re: bumper mesh
Postby tsoob » Wed Apr 07, 2010 2:33 pm
superxpensive lol
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby sergei » Wed Apr 07, 2010 4:33 pm
Hot glue gun.
or
Double sided tape.
Postby Bling » Wed Apr 07, 2010 5:26 pm
Whatever you do, do it right. Double sided tape? :lol: :lol: Rangi au
I used a 2 part glue to put mine in. Just folded the mesh close to the bodykit, then put a good blob of that stuff on every so often. Hasn't budged at all and has been there for years.
Postby sergei » Wed Apr 07, 2010 5:42 pm
BZG|Bling wrote:Whatever you do, do it right. Double sided tape? :lol: :lol: Rangi au
It is a cosmetic mesh.
The right double sided tape is better than glue.
Most of factory mouldings are on double sided tape.
Postby DeeCee » Wed Apr 07, 2010 6:39 pm
and generally side mouldings have a lot more surface area for adhesion. Polyurethane will do the trick. Depends on if you want it to come out later.
GT Four Adovansu
DeeCee
Postby Stott69 » Wed Apr 07, 2010 7:18 pm
Drift spec with cable ties 8)
Image jzs147 Aristo money pit
Stott69
Postby tsoob » Wed Apr 07, 2010 7:39 pm
i have some liquid nails i can try, or some sturdi bond construction adhesive.
nah not gonna rangi it up bro.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby matt dunn » Wed Apr 07, 2010 7:50 pm
Windscreen Urethane would be what I would use.
Postby MR2BOY23 » Wed Apr 07, 2010 8:04 pm
Yup sikaflex (from superxpensive) should do the trick
MR2BOY23
Postby eskimo » Wed Apr 07, 2010 8:22 pm
MR2BOY23 wrote:Yup sikaflex (from superxpensive) should do the trick
Sikaflex is the Sh1t. Should work no worries
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby frost » Wed Apr 07, 2010 8:59 pm
i do love sikaflex but maybe a bit expensive for just sticking mesh on,
if the liquid nails will bond to the glass ok then i'd use that,
at $12 a tube you could go crazy with it,
Postby DeeCee » Wed Apr 07, 2010 10:13 pm
just watch the solvent liquid nails on one's hands. Its an absolute bitch to get off, so use gloves. A friend uses it for his sub boxes and every time, he gets it on his hands and takes weeks to remove.
Sikaflex 252 is teh structural bonding polyurethane. Requires mechanical removal (ie grind it out) to remove it lol.
- For using adhesives, rough up section where adhesive will go - allows for better bond between surface and adhesive.
- Then clean up so there are no particles to interfere between surface and adhesive.
- Wet rag and clean as you go for best finish.
- If you are putting item under tension, use wax paper between clamp and adhesive for easy removal of clamp and clean finish.
GT Four Adovansu
DeeCee
Postby tsoob » Thu Apr 08, 2010 3:41 pm
ahk sellys all fix it is!
will put the pics up in my thread shortly
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby .:O4AGTZ:. » Thu Apr 08, 2010 5:22 pm
DeeCee wrote:just watch the solvent liquid nails on one's hands. Its an absolute bitch to get off, so use gloves. A friend uses it for his sub boxes and every time, he gets it on his hands and takes weeks to remove.
I know what you mean! Gorilla Grip as well...holy $#!+ literally weeks before it comes off. Any attempt and it will not budge. You just sort of have to peel it as it becomes available.
Yup All Fix is the best solution first up. Cheap and good.
.:O4AGTZ:.
