Dell'Orto wrote:Not using Mobil 98 E10 are you?
sergei wrote:If temp goes down on highway your thermostat is poked.
maddog wrote:sergei wrote:If temp goes down on highway your thermostat is poked.
I've noticed that the temp. gauge in my 101 FX GT acts the same as TRD_ZERO describes; I've also heard of this exact same behaviour from a work colleague's 101 FX GT, can anyone shed some light on this?
matt dunn wrote:If the temp drops on the open road compared to normal,
the it will use more fuel as it will be running on cold fuel program.
