Caldina GTT Cam belt
Postby Lac » Tue Mar 02, 2010 8:04 pm
Hey,
I know its been asked a bit and i have done the searching but just want to confirm when i do the cam belt change. Im coming up to 90k so going to get it done next service. I want to make sure i do it right the first time.
Caldina GTT
Cam belt
Tensioner pulley
auto tensioner
idler pulely
all seals (2x cam 1x crank 1x oil pump)
water pump
tensioner bolts
thermostat
Anything else?
Caldina GTT Sydney
Lac
Postby jaypines » Tue Mar 02, 2010 10:58 pm
dont forget the o-ring behind the oil pump... these can leak over time. inspect drivebelts as well.
jaypines
Postby Lac » Mon Mar 22, 2010 7:44 pm
Can you get the the timing belt replaced in a kit? That comes with all the parts together? Any one know a toyota part number?
Lachlan
Caldina GTT Sydney
Lac
Postby 1I1 » Mon Mar 22, 2010 7:49 pm
Toyota sells all the bits you need separately..
TRD Clicky >>Here
1I1
Postby Warren » Fri Apr 16, 2010 11:09 am
Did you do this in the end?
Just out of curiousity, how much did it cost you?
Mr. T says "Don't do school, stay in milk, and drink your drugs"
Warren
Postby Lac » Fri Apr 16, 2010 1:40 pm
Yer i did actually, big thanks to Mark. Total cost was 399.10 plus GST,
Caldina GTT Sydney
Lac
Postby Warren » Sat Apr 17, 2010 12:20 pm
Lac wrote:Yer i did actually, big thanks to Mark. Total cost was 399.10 plus GST,
Awesome, was that for everything? (Cam belt, Tensioner pulley, auto tensioner, idler pulely, all seals (2x cam 1x crank 1x oil pump) water pump, tensioner bolts, thermostat etc etc)
Warren
Postby Lac » Wed Apr 21, 2010 5:01 pm
Yep everything
Caldina GTT Sydney
Lac
