anyone got part number or know what this starter is of original
suit 4age
http://cgi.ebay.com/ebaymotors/4age-STA ... 439ea42753
frost wrote:its for rwd so its a 1G starter,
needs a 9mm spacer for it to work and to center it,
picture slightly different being older model but mounting is the same,
NZ_AE86 wrote:frost wrote:its for rwd so its a 1G starter,
Not quite.
try a factory AE86 starter, some models had this type of reduction drive starter from the factory.
part No. 28100-15130 or 15180 if it came off a AE92 (hard to say as the seller says it suits both, although it looks exactly the same as one I have which is AE86/15130 but I don't have a 15180 to compare)
thegreatestben wrote:Isn't the one you want a smallport starter? old style bolt pattern but with 20v style starter guts?
