mistyq wrote:We have pulled the codes from it 14 & 15 which we have found out meant ignition coil amplifier 1 & 2,
The fault still exists but no fault codes present in ecu, even though the check engine light comes up when driving.
mistyq wrote:Spoke to (yet) another auto sparky, suggestions now are fuel system (pump/filter, possibly caused by poor maintenance),
power relays, a bad earth or even the immobiliser on the alarm.
Snaps wrote:Does the engine use any sort of Idle air control valve (a small thing that looks like a TPS from the outside, after the throttle butterfly)? I had this same problem on my supra (although no CEL), and the IACV just needed a really good clean. After that I reset the ECU and it hasn't happened again yet. I may be way off lol, but it's worth an ask.
mistyq wrote:Right.... Now it played up like a bag a f..ken sh.t today, but i drove it around and around and around missing, coughing and backfiring, with check engine light coming on, i shorted wires out off and on as i drove waiting for a fault to show and i managed to get a fault logged (12) "crank pos sensor" so i know where to start looking now,
mistyq wrote:he is a link of what it looks like plus some points on why gen 4 is diff to gen 3 3sgte. http://www.alltrac.net/phpBB2/viewtopic.php?=&p=166076
mistyq wrote:Really??!! i read what a fault 12 is on the net at this address http://bitcrusher.org/3S-GE_Codes_List.pdf crank pos sensor 1 and somewhere else i forget where told me number one is crank sensor,
mistyq wrote:but where is your thread for fault codes or do you have a book or something?
there so much diff info out there had to know what s true and what is false.
So where do you think i should go from here replace the cam pos sensor?
