have searched but found conflicting info. Want to remove the speed limiter on bzg, With out buying an extra computer etc
Can some one send me a link for this.
Thanks
fivebob wrote:It's not really a good idea to modify the signal going to the speedo as it will cause it to read 1/2 of the speed you're actually doing and possibly cause problems with other systems that use the speed input, though I'm not sure if there are any other things that use the speed signal on a 20v.
It's better to modify the signal that's going to the ECU as that won't affect anything else.
Mr Revhead wrote:fivebob wrote:It's not really a good idea to modify the signal going to the speedo as it will cause it to read 1/2 of the speed you're actually doing and possibly cause problems with other systems that use the speed input, though I'm not sure if there are any other things that use the speed signal on a 20v.
I have seen an AE111 20v with a switch to the speedo that switches it off. Disables speedcut. As well as speedo and odometer![]()
Doesn't affect anything else on that car.
mr30%jr wrote:after that they used a pick up screwed to the gearbox and electric everything so both connected to that.
