st165? who has one... or two?
Postby Mr. Mainstream » Tue Apr 20, 2010 9:04 am
bit offpost but what were the diffs like on the 165? forward push or grabby?
ace cars
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby sergei » Tue Apr 20, 2010 9:06 am
Mr. Mainstream wrote:bit offpost but what were the diffs like on the 165? forward push or grabby?
ace cars
On prefacelift (majority of 165) they are all open, with centre manually lockable. Thus it feels like FWD. Hence me using ST205 gearbox and rear diff.
Postby mr30%jr » Tue Apr 20, 2010 10:28 am
yea they can be a put push or pull on the old gearbox
the viscous centre box is alot better i have them for both of my st165s. you can pick them up fairly cheap too
there was days when it would act like a rwd, and also just decide to sledge you everywhere
then days it would just decide to be a front tug hahaha
mr30%jr
Postby RunningRich » Tue Apr 20, 2010 2:01 pm
Suspension setup has a lot to do with it. Mt ST165 had hard Bilsteins and it was definately rwd orientated.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Scottie » Tue Apr 20, 2010 8:18 pm
sergei wrote:On prefacelift (majority of 165) they...
http://gtfour.supras.org.nz/ST165%20description.htm
The ST165 was released in October 1986. The first 2274 cars produced were for the Japanese market only. They differed from the later cars in a number of aspects, including a different gearbox (with a manually locking centre differential instead of the later viscous differential). The front brake calipers are different and the front spoiler has the bottom edge painted black. They also lack the facelift changes made to all Celicas in 1987 (grill, taillights and interior changes). Due to the limited production run these are the rarest GT-Four model of all (possibly excluding the ST185 Rally).
Not sure is Mr Richard was referring to all ST165s or just pre facelift with the "rarest GT-Four" comment.
I have seen ST165s with chassis numbers over 8000
In regards to the understeer/oversteer issue? If you put a stiffer anti-roll bar in the rear it helps a bit apparently, promoting a bit more oversteer. I had one made up by Smiths Steel I think, through autolign. Yet to be tested in the project car as the fuel tank and rear subframe are in bits.
Scottie
Postby sergei » Tue Apr 20, 2010 10:15 pm
I get plenty of oversteer now, no understeer at all, unless stupidly coming in without any power.
Saying that I have stiff bilstein shocks, white line swaybars and strut braces.
Postby Scottie » Tue Apr 20, 2010 10:31 pm
nice Sergei. When did you get the whiteline swaybar? I tried getting one about a year ago with no luck. They sent me a ST185 item. Which is similar but dose not compensate for the bulge in the floor where the abs unit is under the rear seat.
They no longer make the st165 item
Scottie
Postby dnalunchie » Tue Apr 20, 2010 10:47 pm
Scottie wrote:nice Sergei. When did you get the whiteline swaybar? I tried getting one about a year ago with no luck. They sent me a ST185 item. Which is similar but dose not compensate for the bulge in the floor where the abs unit is under the rear seat.
they are discontinued through whiteline mate. Your only chance would be to keep an eye on trademe and ebay
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby Scottie » Tue Apr 20, 2010 11:01 pm
Yer. they still have the jig I think. Autolign contact tried to see if whiteline could get one made as a 1 off. But it ended up being cheaper to have one made here.
Scottie
Postby mr30%jr » Wed Apr 21, 2010 11:16 am
ahh well heres where it gets tricky
there is pre pre facelift, facelift and some other prefacelift hahaha
different combos of transmission and not having new taillights a Grey or Brown grille
out of the few ive seen and the 3 ive owned ive seen 3 different combos.
a few pics of my first faw
never should have $&#$% this car up....
but as you can see the grille doesnt go under lights.
but i have 2 different grilles which do go under the lights.
i sold it to howard in auckland who seized it then i bought it back and it disapeared off the face of this earth... so if anyone has a badly painted st165 floating around i would like it back its very centimental to me.
mr30%jr
Postby celica_xr9145 » Fri Apr 30, 2010 10:48 pm
If anyone is interested, down here in Dunedin in a car sales is a ST165 rally car (think its the red and white repsol one?) in the front window. Not sure if its a replica or genuine, will get a better look tomorrow, didn't see if its for sale either :? Car sales is auto court at the end of andersons bay road if anyone local wants to take a look.
www.Garage-X.org - Car Awesomeness
Facebook.com/garagexnz - Now on FB!!
95' Zenki Silvia S14, 99' BMW 328i E46
celica_xr9145
Postby mr30%jr » Sat May 01, 2010 8:47 am
its a TTE been adapted to rally. if its built the same it was a few years ago its a demon...
mr30%jr
