Could someone who has one of these installed possibly check behind there unit for me? Or someone who is wrecking a Caldina?
Here is the part i am trying to fit
Staplez wrote:if you are really dead set on getting this to work in your car I probably have a dash loom that would have the plug to fit this. But it will take up some time pulling the whole dash out to switch out the loom. in my opinion it's not worth all that trouble unless you can read Japanese.
The blue plug you mentioned did that have a cap on the end of it covering the pins? because there should actually be two of these plugs and niether have anything to do with this unit.
