Truenotch wrote:
You can add front stays and side intrusion to a half cage, no problem. To do this you have to make it to the right specs and get a "homologation extension". This basically consists of re-drawing the cage design to the new specs, getting the engineer to fill in a form and having MSNZ sign it off.
very minor correction, essentially you're 90% right. It is no problem to change from a half to a full cage. But it's not done through an extension, it is done through a new homologation. Really only a paperwork difference though, your main point is totally correct.
If you're doing stuff like adding or changing intrusion bars to a cage, or some diagonal brace bars or such, then it is done through an extension. But when you're altering the principle structure design, then it's a fresh homologation.
Full cage in a daily driver is a nightmare. You duck and bend every time you get in and out of the car, and you have to adjust the belts every time. Reversing in belts is a prick. You wear out your belts super fast too. I've seen a set of FIA Silvester belts (two sets actually) completely poked in the shoulder straps in slightly over a year. Just because they didn't like that many adjustments (every time he sat in the car).
