Oxy sensor on red top
Postby petrolhead » Tue Apr 20, 2010 9:02 pm
hi guys. i have just fitted a set of 20v headers to my red top and found oxy sensor hole is a totally different setup (20v has a screw in type further down the header, read top has a bolt on flange). Does anyone know whether you can wire the screw type in, as well as extending the loom to reach the hole further back? cheers
Hewies
Race and Restoration
petrolhead
Postby levinguy » Wed Apr 21, 2010 12:21 am
off topic but, that seems a bit weird, i've had 3 silvertops, all with the flange type oxy sensors, is this a facelift/prefacelift thing?
levinguy
Postby sergei » Wed Apr 21, 2010 9:51 am
As far as I am aware 20v are flange type (and 4 wire). Plugs differ between blacktops and silvertop.
Postby petrolhead » Wed Apr 21, 2010 6:39 pm
Ahh forgot to mention they could be aftermarket headers. 8) hmm.. might get a flange welded to exhaust. Spare sump plug filling hole at the mo.
Hewies
petrolhead
Postby mr30%jr » Thu Apr 22, 2010 12:08 pm
yea sounds like youl have to find a screw type oxy single wire with no heater for redtop
mr30%jr
Postby Staplez » Fri Apr 23, 2010 4:19 pm
One of my co-workers uses a bosch universal 4 wire oxy sensor in his silvertop. If thats any help at all. But i take it the loom still has a 1 wire plug?
Try pick a part for oxy sensors off camry's or celicas i think most have 1 wire screw type that will fit.
one more tip do not cut the oxy wire before the plug if you need to change it. It's not a typical wire inside and cutting can change the behaviour of the oxy reading
ST215 Owner
Staplez
Postby mr30%jr » Fri Apr 23, 2010 4:30 pm
silvertop drives a heated 4 wire
mr30%jr
Postby Staplez » Fri Apr 23, 2010 5:01 pm
Yeah i know but from what i gather is that the head is a silver top while the remainder is the original redtop loom included i'm asuming, or did i miss something?
ST215 Owner
Staplez
Postby rollaholic » Fri Apr 23, 2010 5:06 pm
no he has a silvertop exhaust manifold on a 16v red top head
Postby petrolhead » Fri Apr 23, 2010 6:27 pm
rollaholic wrote:no he has a silvertop exhaust manifold on a 16v red top head
That is correct. Looks like i will try find a camry one.
Hewies
petrolhead
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
