powersteering hose repair
Postby gleem » Fri Apr 23, 2010 9:14 pm
my power steering lines leaking were the rubber hose meets the metal line crimping. Tried everywere to get a replacement and pick a part 5 times. Only option now is really to go to a hydrolics shop. Any body know of cheap ones in auckland?
gleem
Re: banjo bolt oil feed sizes/diameter
Postby Phothog » Sat Apr 24, 2010 10:13 am
gleem wrote:just doing some turbo work on my nissan rb. Took the banjo bolt of the trubo for the oil in feed and saw the size of the hole the goes from top to bottom is the size of a ball point pin tip. So all the oil that will go through the turbo has to come through this which just doesnt sound right. Is this what they normally are or shoud i drill it out a bit?
If its a factory Rb turbo (Ball beaing & ceramice turbine wheel) than yes leave it alone, if its not a factory unit and a normal Journal bearing turbo then yes drill it out.
gleem wrote:Also my power steering lines leaking were the rubber gose meets the metal line crimping. Tried everywere to get a replacement and pick a part 5 times. Only option now is really to go to a hydrolics shop. Any body know of cheap ones in auckland?
Dont know any cheap ones, but Cental Hydrolic Services at 205 archers road does a good job.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby gleem » Sat Apr 24, 2010 11:20 am
yeah went there, $210. Rather wait aroumd to find a second hand one. Hose is all removed etc
gleem
Postby gleem » Tue Apr 27, 2010 2:19 pm
bump
gleem
Postby no_8wire » Tue Apr 27, 2010 2:49 pm
Tried Enzed, Waitamata Hydralics etc?
no_8wire
