Celica SSIII
Postby dnalunchie » Thu Apr 22, 2010 9:39 pm
Alex B wrote:The biggest issue is, it appears to not be a V9 WRX.
a valid point
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby ®usty » Fri Apr 23, 2010 3:17 pm
Mr Revhead wrote:
®usty wrote:and superstrut (bit different to the ST205) and stronger brakes- 2pot in the front
Is it? What's different. My memory suc, but I thought it was the same as 205?
the hubs are different (since the gt4 run the 4pot brake calipers)
I get different part numbers (must be bigger or stronger) to take the extra weight & power???
The biggest problem with a celica is they are considered more [person of homosexual orientation] than an MX5.
Absolutely nothing wrong with them, I would own certain models, but it's the stereotype. Unless, you park next to a curren....
poo
®usty
Postby gt4dude » Sun Apr 25, 2010 2:58 pm
Be ware of what you're actually getting, Not many people know much about NA Celicas.
A real SS-III can sometimes be difficult to differentiate from an SS-II, but some giveaways are -
SS-III always has "Superstrut Suspension" written on the bottom of the rear windshield.
SS-III chassis code is E-ST202-BLMZF
LSD comes with Superstrut equipped Celicas that have a Manual transmission ONLY. No other Celica comes with it. The Trans/Axle code is S54-06D
A redtop 3S-GE Beams motor doesn't neccessarily mean SS-III, It's a year thing, not a trim thing. Other cars including the MR2 G-Limited and the Celica SS-II also had the same motor from Late 1997 onwards, they did NOT come with LSD.
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
