I think its off a celica?? but not sure which model...
strx7 wrote:I suspect those discs are the type i'm currently trying to find.
strx7 wrote:why do you think it is off a celica? GT4 calipers bolt straight onto corolla hubs. Does it no longer have the factory drive flange?
strx7 wrote:AE9# and AE10# hubs, the GT4 caliper has the same bolt spacing, i'd reccomend tapping the hub carrier provisions and bolting thru the caliper into the hub carrier. you could run a 285/286mm disc, either something about 35ish mm total height or approx 62mm height dependings on which side of the carrier lugs you mount the caliper.
I'm currently trying to get a 310mm x 22mm mercedes disc to use with my RX7 4 pots which will just squeeze under the 16x7's i have with 225's on.
strx7 wrote:RX7 calipers have less "overhang" than GT4 calipers.
It call comes down to a) what rims you run, b) what total height the disc is.
