1JZ-GE - new car to me, have some questions
Postby 1I1 » Tue Apr 27, 2010 2:54 pm
gt4dude wrote:I'm using 25L per 100km to and from work with 30% motorway driving
This is figured from a round trip of 61kms with 22kms of motorway driving costing me $15 per day at the current rate of 1.98/L for BP Ultimate 98.
Car is an untuned 1996 ST205 Celica GT-Four with a Gen 2 turbo on a Gen 3 engine (CT26).
8O
My 1.5L Lancer on its last fill did 33L over 415km commuting between Feilding and Palmy
TRD Clicky >>Here
1I1
Postby ~SlideWays~ » Tue Apr 27, 2010 3:40 pm
I got about the same in a close to 3000kg, 3.8L petrol, auto, 4wd with huge power sucking mud tyres 8O
~SlideWays~
Postby Jingle Balls » Tue Apr 27, 2010 3:57 pm
yeah that sounds abysmal. the wrx i mentioned before has a t04e turbo on 20psi with 800cc injectors and doesn't get driven lightly, and would use about half of that
but still...any one know about the oil on cylinder 5 spark plug? Research has lead me to believe it is a leaky valve cover seal. What is this and is it pretty easy on this motor?
Jingle Balls
Postby sergei » Tue Apr 27, 2010 4:27 pm
Something seriously wrong with your tune.
What ECU are you using? Injectors?
Why gen2 turbo (in stock they are rubbish)?
25L/100Km is really bad.
Postby FANGIN » Tue Apr 27, 2010 4:48 pm
Crikey, I used 1/8 ish of a tank (9.25litres) IDLEing / getting the RX7 to Idle properly on saturday, think the 850cc primary injectors may have something to do with it though.... the damn thing almost makes boost at idle too 8O
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby Emz » Tue Apr 27, 2010 5:12 pm
Get a Vitz. $40 gas gets me about 500kms lol
My 2j however is roughly 6km/L :(
'97 Supra RZ - Click Here! | Discussion thread - Click Here
Emz
Miss Supra Princess
Postby phoenix » Tue Apr 27, 2010 7:12 pm
That's seriously bad maths.
$15 - 61kms
7.6L - 61kms
= 12.4L/100km
phoenix
Postby metal_sean_head » Tue Apr 27, 2010 7:25 pm
Yeah lol
$15/$1.98L = 7.576 litres of 98 for $15.
100kms/61kms =1.64
7.575*1.63= 12.42L/100kms (i just rounded up a bit so its about 12.4L/100kms)
So yeah i don't know where you got 25L/100kms from.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Adoom » Tue Apr 27, 2010 8:09 pm
Hmmmmm
My 1.5 AE100 nanna spec does 13kpl....7.7L per 100km
THE STARVIA 1.8turbo does 7.5kpl....13.3L per 100km
The 1UZ Soarer did 7kpl.....14.3L per 100km
Adoom
Postby gt4dude » Wed Apr 28, 2010 4:13 pm
HAHAHA I don't know where I went wrong either oops !!!!!
EDIT: Ohh crap, I divided 100 by the trip to work, not the round trip man what a dumb a$$.
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
car
Postby docTRD » Wed Apr 28, 2010 8:57 pm
I would expect a 1jzge jzx90 to get around 10L/100k motorway driving, thats what the russian auto.vl.ru says aswell. 1jzgte powered autos usually get 11-12 so its not that high i dont think.
my 1gfe gx90 was a sack and was so slow and chewed about 10L/100k for no fun at all! at least 1jz motors like to rev for your money :)
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby Looonie » Wed Apr 28, 2010 11:33 pm
I get 500km off a tank.
*shrug*
Rumple dee pumple dee doo...
Looonie
Postby sponsormycrown » Thu Apr 29, 2010 10:54 am
shit no one answers the actual questions on the thread? yes valve cover is easy but you have the na version so u will have to remove part of the intake but thats pretty easy too. shouldnt take you more than an hour to do
how were cars built without the internet in the 90s?
sponsormycrown
Postby Jingle Balls » Thu Apr 29, 2010 12:51 pm
sponsormycrown wrote:sh*t no one answers the actual questions on the thread? yes valve cover is easy but you have the na version so u will have to remove part of the intake but thats pretty easy too. shouldnt take you more than an hour to do
thanks for the response, yeah was noticing a trend with that :lol:
removing the intake isn't too hard, i had to do that to change the plugs. i don't actually know what or where the valve cover is though, nor where or what the seal is sealing...lol Is the oil on the plug likely to be caused by this seal?
Jingle Balls
Postby blindnz » Thu Apr 29, 2010 1:36 pm
yeah most likely valve cover, the other cause if its similar set up to a 4age is aluminium o rings under the hex studs.
someone will confirm this.
blindnz
Postby sponsormycrown » Thu Apr 29, 2010 1:39 pm
yea bloody internets no takes this business seriously :lol:
umm if the oil was caused by the gaskets leaking you would have a oil leak/pool in the middle of your cylinder heads around your spark plugs. so unless there is oil around the number 5 plug its prob coming from inside the engine. i doubt its anything serious. drive it for a while and take the plugs out again and compare if its still there do a compression test
sponsormycrown
Postby sponsormycrown » Thu Apr 29, 2010 1:43 pm
blindnz wrote:yeah most likely valve cover, the other cause if its similar set up to a 4age is aluminium o rings under the hex studs.
they have 2 seperate sides, intake and exhaust the sparks are just covered by a spark plug cover(plastic) and not a part of the oil side of the engine
sponsormycrown
Postby Jingle Balls » Thu Apr 29, 2010 3:25 pm
is it even possible that the valve seal is allowing oil onto one plug? would it not be more likely to be all of them? A leaky piston ring has been another suggestion. it was quite a bit of oil, perhaps up to a teaspoon or so
Jingle Balls
Postby sponsormycrown » Thu Apr 29, 2010 4:08 pm
normally it would affect cylinder 6 too if you pull it apart and have a look at it you should be able to see oil sittin on top of the engine around the spark plug. if there is no oil on top of the engine or leaks from the covers its internal!
sponsormycrown
Postby gt4dude » Thu Apr 29, 2010 4:44 pm
maybe just crc that oil down the hole and put your plug back in and see if oil builds up again. the yellow tarnish is usually just the ceramic shit discolouring from heat, very common.
200AWKW / 370NM
gt4dude
