metal_sean_head wrote:yeah was thinking sway bars. Also do rear strut braces do alot? ive got a factory front one which im inclined to upgrade. And also for the front one, am i correct in saying one which goes from the strut towers to the firewall are better?
I guess my main question was should i modify my red top now? with usual bits, exhaust, intake? or do everything else sorta first and then see where my engines at. i just don't want it to blow up after doing a spending a bit on it, replace it and have to do it again. you know? might be un avoidable though
B1NZ wrote:also a whiteline adjustable rear sway bar is good bang for buck and removed the factory understeer issues
Dell'Orto wrote:B1NZ wrote:also a whiteline adjustable rear sway bar is good bang for buck and removed the factory understeer issues
You could do worse than read the posts in your thread...
