1jzgte clutch issues
Postby drift-monkey » Wed Apr 28, 2010 2:46 pm
Hi guys i was wondering if someone could give me their views on this, i have a custom flywheel from branden at a1 turbos and went to order in the clutch kit tyk-7332 and it doesnt fit, if anyone else has used this flywheel in their project would you be able to tell me what clutch kit you used? all the part shops keep telling me i need a push style clutch at the cost of $1700 witch i know isnt right as i told them i am not using a r154 box, im using a w series.
drift-monkey
Postby Jebus » Wed Apr 28, 2010 2:56 pm
Is that the kit Brendon told you to get? Should be from a 2JZGE supra?
If thats not the one you have get that one, if it is then the flywheels probaly drilled wrong.
Edit: just checked exedy, you have the right clutch. id check with Brendon becuase they probaly drilled the flywheel wrong.
Jebus
Postby drift-monkey » Wed Apr 28, 2010 5:02 pm
yea man it is, ah man thts thats a bugger hes out of the country atm to. so thats the one i need then? autostop arent steering me in the wrong direction?
drift-monkey
Postby Jebus » Wed Apr 28, 2010 5:58 pm
Im not sure sorry dude, take the clutch and flywheel to precision engineering and get them to drill it to suit your clutch. easy peasy
Jebus
Postby nite b » Wed Apr 28, 2010 7:38 pm
Hey, just got back in NZ. Give me a buzz if any issues. Cheers!
Convert Ltd
The conversion specialist
nite b
