Rych wrote:wow learn something new everyday. So everyone who claims "my car makes this much hp" means nothing. All the XXXKW ATW in magazines is just a rough estimate?
I don't mean at the engine, but a dyno measuring power at the wheel still can't measure power at the wheels properly?
Rych wrote:I didn't realize how inaccurate dyno's are. So you mean to say you can't just go take your car to get dyno'd and see how much power it's making because most likely it could be way out and won't mean anything?
Surely there are accurate ones around???
sergei wrote:Akane wrote:Funny how I keep hearing people allowing crazy % of "drivetrain loss".
If it's true, after a bit of track time, your gearbox will turn into an ingot.
It is not % anyway. It is non-linear.
Akane wrote:
but to lose 70kW+ (about 35 heaters on MAX POWER), you got tungstun gearbox or something?
strx7 wrote: The only way you can accurately say that you are making X HP at the wheels is to attach an engine dyno to your wheels
Jingle Balls wrote:best dyno is quarter mile trap speed vs weight. i'
matt dunn wrote:strx7 wrote: The only way you can accurately say that you are making X HP at the wheels is to attach an engine dyno to your wheels
How is that any different to any other dyno attached to your wheels?
Why is an engine dyno more accurate to any other?
What happens if you attach a wheel dyno to your flywheel?
strx7 wrote:Jingle Balls wrote:best dyno is quarter mile trap speed vs weight. i'
Only if wheels, tyres, diff ratio, gear ratios etc are all exactly the same. Otherwise there is too many variable just different types of rolling road dyno's
matt dunn wrote:and when the dyno guy tells you it has just been calibrated,
calibrated against what?
Did they apply 400hp to the dyno and calibrate it to that?
Or did they just plug in a laptop to it and adjust it's brain a bit?
IMO there is no such thing as an accurate dyno,
as something like that is just not capable of being accurate.
And IMO engine dyno would be the same.
Two different brands of engine dyno would probably read different too.
