headgasket - 4age
headgasket - 4age
Postby NOLAW » Sun May 02, 2010 9:33 pm
Hey can anyone tell me if you can buy a 2.5-3mm headgaskeet for a smallport ae101 4agze block and if so where from?
any help would be great
NOLAW
Postby 4agtepwr » Sun May 02, 2010 9:42 pm
Why such a thick gasket?
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby NOLAW » Sun May 02, 2010 10:20 pm
need to drop the compression as iv gone turbo, and the compressions to high to run anymore than around 10psi and iv been told even then that could be pusing it
NOLAW
Postby Mr Revhead » Sun May 02, 2010 10:23 pm
Whats your compresion :?:
Postby matt dunn » Sun May 02, 2010 10:31 pm
NOLAW wrote:need to drop the compression as iv gone turbo, and the compressions to high to run anymore than around 10psi and iv been told even then that could be pusing it
Really as I have seen GZE's with standard head gaskets run up to 20 psi successfully.
Is it a GE or a GZE that you are refering too,
and who told you that?
Postby sergei » Sun May 02, 2010 10:38 pm
Thicker head gasket does not help with detonation. Even if you drop compression via headgasket, you are removing squish areas which increases detonation.
Postby 4agtepwr » Sun May 02, 2010 11:39 pm
What 4age is it? what pistons?
4agtepwr
Postby Burning Angel » Mon May 03, 2010 7:14 am
sergei wrote:Thicker head gasket does not help with detonation. Even if you drop compression via headgasket, you are removing squish areas which increases detonation.
exactly, thicker headgasket is the worst way to reduce compression, if anything you want a thinner headgasket to improve squish and change compression with pistons.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby mr30%jr » Mon May 03, 2010 8:18 am
sounds like another clever cooky is going to have go at turboing on standard pistons :lol:
mr30%jr
Postby NOLAW » Mon May 03, 2010 9:47 am
its not GE its a ae101 GZE, and from what iv been told gze pistons handle fine mr clever up there ^
NOLAW
Postby Mr Revhead » Mon May 03, 2010 9:50 am
are you wanting to run like 20psi on the stock ecu?
Postby NOLAW » Mon May 03, 2010 9:52 am
i got 145kw on 5psi and was told the compression was rather high by brent at dynopower (200 on each cylinder) and he reconed i would only be able to run 10psi and even then that would be pushing it and i want to run about 15psi and no its running a link g3 with electronic boost control.
I think the compression on the late model gze's is about 8.9:1, is this to high to run 15psi on?
NOLAW
Postby ~SlideWays~ » Mon May 03, 2010 10:06 am
NOLAW wrote:i got 145kw on 5psi and was told the compression was rather high by brent at dynopower (200 on each cylinder) and he reconed i would only be able to run 10psi and even then that would be pushing it and i want to run about 15psi and no its running a link g3 with electronic boost control.
I run just under 18psi on 8.9:1 pistons, can't remember what the compression results were though.
But 145kw is pretty high for 5 psi! Maybe your head has been skimmed a few times in its life?
~SlideWays~
Postby NOLAW » Mon May 03, 2010 10:46 am
from what i know of it hasnt been skimmed but i could be wrong, what are other compression readings people have had from there gze's if theres anyone else out there whos had it done?
NOLAW
Postby sergei » Mon May 03, 2010 11:00 am
NOLAW wrote:from what i know of it hasnt been skimmed but i could be wrong, what are other compression readings people have had from there gze's if theres anyone else out there whos had it done?
Compression reading is not relevant to compression ratio.
Postby NOLAW » Mon May 03, 2010 12:20 pm
yeah well the whole compression thing is all new to me so thats why im asking for advice and trying to get to grips on how it all works and what i should do
NOLAW
Postby sergei » Mon May 03, 2010 12:25 pm
NOLAW wrote:yeah well the whole compression thing is all new to me so thats why im asking for advice and trying to get to grips on how it all works and what i should do
200PSI (13.7Bars) is good, but that does not mean that you have 13.7 compression ratio. Compression tests will only show if there is a problem with a specific cylinder, unless the reading are too low.
Postby evil_si » Mon May 03, 2010 12:54 pm
if its still the same engine its never been apart from what i remember,
so should all be standard inside,
i wouldnt be looking at changing it,
compression test doesnt tell you the compression ratio
evil_si
Postby NOLAW » Mon May 03, 2010 1:17 pm
hey si, yeah its the same engine and i havent touched the internals so you recon it would be alright to up the boost with out doing anything with the head/gasket?
NOLAW
Postby evil_si » Mon May 03, 2010 1:25 pm
yup, to be honest i wouldnt worry about it,
evil_si
