quiet exhausts
Postby metal_sean_head » Thu May 06, 2010 11:41 am
Do removable silencers have to be welded in? Or is the single nut and bolt all goods
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby xsspeed » Thu May 06, 2010 12:04 pm
depends on your wof man
Postby B_giB » Thu May 06, 2010 12:31 pm
metal_sean_head wrote:Do removable silencers have to be welded in? Or is the single nut and bolt all goods
Technically they need to be welded in
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby xsspeed » Thu May 06, 2010 12:33 pm
^ Debateable.
A nut and/or bolt/screw still requires tools to adjust/alter.
Depends on the interpretation from your wof man.
Postby metal_sean_head » Thu May 06, 2010 4:45 pm
I thought they had to be welded in. Failed my warrent for my exhaust last year at VTNZ. Went and got a silencer and just bolted it in. They were fine with it. I just thought VTNZ would have picked it up. My normal WOF guy doesn't even glance at it. Although i have it in permanently now so its all blackened. You hardly know its in there.
But like is it illegal to drive on the road with it bolted in?
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Bling » Thu May 06, 2010 4:50 pm
xsspeed wrote:^ Debateable.
Only if you do the bolt up too tight :lol: Could always rivet it in for wof as that's certainly not something you can undo without tools
Postby metal_sean_head » Thu May 06, 2010 4:55 pm
How easy is a rivet to get out if you want it out? Say for a track day or something?
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby xsspeed » Thu May 06, 2010 4:56 pm
Got a drill? That easy
Postby DRFTIN » Thu May 06, 2010 6:00 pm
i thought the rule said silencers have to be permanent?
bolt arent very permanent
DRFTIN
Postby xsspeed » Thu May 06, 2010 6:06 pm
Using a hand tool you can remove a muffler in 10 mins. (Hacksaw)
Even less with Dr Makita.
Postby MR2SIK » Thu May 06, 2010 11:37 pm
MR2SIK wrote:that was the system I had on that got me the green sticker.
So I tacked in a silencer/baffle for the first recheck and that still failed. Now the exhaust is factory from the downpipe back.
They even hummed and ha'ad about the fricken downpipe, so I nutted at them at how would it affect the sound...
Depends on WOF man, as said a couple of years ago, they still failed me even after silencer was welded in, said it was too easy to remove, took a bloody angle grinder to get it out :evil:
So I got the factory zorst flanged so I can swap it back to the straight thru in a few minutes.
Also, whos the grave digger here? :lol: thought I was going crazy with not remembering starting this thread recently.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
