oil leak.
oil leak.
Postby sark.inc » Wed May 05, 2010 8:06 pm
Oil leaking from the head gasket, what is the general cause of this?
bad head gasket?
sark.inc
Postby rollaholic » Wed May 05, 2010 8:12 pm
dont buy a mitsubishi
Postby sark.inc » Wed May 05, 2010 8:49 pm
it's my 4age ST, just started turning it over to get oil pressure up to start it and found oil PISSING out the side of the block.
sark.inc
Postby Mr Revhead » Wed May 05, 2010 8:52 pm
rollaholic wrote:dont buy a mitsubishi
oh lol :lol:
Wheres the oil coming from exactly?
as a descritpion of "pissing out the block" would prompt me to ask "do you know where all your rods are?" :P
Has this just been rebuilt? Or other work?
More details please 8)
Postby sark.inc » Wed May 05, 2010 9:00 pm
oh lol :lol:
just freshly rebuilt, pissing out near number one on exhaust side.
i really have no choice but other than to take it off.
sark.inc
Postby Mr Revhead » Wed May 05, 2010 9:11 pm
I assume you have had a really good look and it is definitely coming out between the head and block? and not the VVT solenoid?
Postby sark.inc » Wed May 05, 2010 10:14 pm
yes i did, someone else also looked as well.
sark.inc
Postby Mr Revhead » Wed May 05, 2010 11:20 pm
Just checking as you never no in these forums! :lol:
Sounds like it has to come off :(
Post back what you find.....
Postby sark.inc » Wed May 05, 2010 11:26 pm
$&#$% raging at it so i am going to leave it till tomorrow, i was THIS [ ] close to starting it :evil:
sark.inc
Postby Dell'Orto » Wed May 05, 2010 11:37 pm
Were the block and head mating faces checked before reassembly? My one leaks like a mofo from the VVT solenoid :evil:
Postby matt dunn » Thu May 06, 2010 12:17 am
Fresh Rebuild?
was the head gasket put on upside down?
Postby mr30%jr » Thu May 06, 2010 11:12 am
i had an issue where oil went down the headbolt thread and actually torqued the head up when it was FAR from done up cause the oil locked the bolt
mr30%jr
Postby YeMs » Thu May 06, 2010 4:22 pm
mr30%jr wrote:i had an issue where oil went down the headbolt thread and actually torqued the head up when it was FAR from done up cause the oil locked the bolt
lol, seen that before. iv also seen it crack the block from hydraulic-ing.
as said id be having a good look around before you pull the head off. however, its only an hour job getting the head off to diagnose.
Your local Hybrid Elite tech
YeMs
Re: oil leak.
Postby allencr » Thu May 06, 2010 7:00 pm
sark.inc wrote:Oil leaking from the head gasket, what is the general cause of this? bad head gasket?
Bad head gasket, No, there is no 'general cause' because this doesn't generally happen, if ever. Unlikely, but it could be a bad crimp or seal on the oil filter & adaptor, the oil pressure sender, or an oil cooler/turbo feed line.
It can't be a head gasket unless YOU'VE just installed it F'd up.
What have you touched recently?
allencr
Re: oil leak.
Postby matt dunn » Thu May 06, 2010 7:41 pm
allencr wrote:It can't be a head gasket unless YOU'VE just installed it F'd up.
sark.inc wrote:[
Number one near the exhaust is where the main oil feed to the head is,
and where the o-ring in the head gasket should seal it,
if you puy it on the right way up and right way round.
My bet would be the gasket was placed steel side down if it's a genuine part.
Postby Brick » Thu May 06, 2010 7:46 pm
my guess to
Brick
I know Kung Fu
Postby l1ttle_d3vil » Thu May 06, 2010 10:10 pm
wheres the oil pressure sensor on ST's?
forgot to bolt mine on when I first cranked my 16v over, had oil pissing out the side of the block, under the dizzy...
Postby QikStarlie » Thu May 06, 2010 10:21 pm
+1 for backwards head gasket
QikStarlie
Postby sark.inc » Fri May 07, 2010 4:34 pm
QikStarlie wrote:+1 for backwards head gasket
sark.inc wrote:[
i agree...... >_<
All my lights work along with the motor cranking over, but i am not getting any fuel along with the battery light staying on after i crank it over? :?
any ideas?
sark.inc
