Tacho not working with coil over plugs setup
Postby ATAl » Sat May 08, 2010 6:25 pm
I'm running coil over plug ignition in my ae92 levin gtz and the tacho isn't working.
Using 1zz-fe coilpacks.
Currently I'm just taking the IGF signal off each coilpack then all four wires are joint together and connected to the tacho wire. I'm assuming this will create a 5v square pattern (might be 12v haven't measured it yet).
Can anyone tell me what the gtz tacho is expecting to see? Voltage spikes or square wave, and how many volts?
Or have I done something fundamentally wrong here?
Cheers.
ATAl
Postby ChaosAD » Sat May 08, 2010 6:52 pm
ChaosAD
Postby ATAl » Sat May 08, 2010 7:39 pm
Ok, so basically I'm going about this the wrong way and the IGF signal is no use as a tacho drive?
ATAl
Postby matt dunn » Sat May 08, 2010 10:15 pm
what ECU are you using to run 4 coils?
Postby sergei » Sat May 08, 2010 11:10 pm
ATAl wrote:Ok, so basically I'm going about this the wrong way and the IGF signal is no use as a tacho drive?
IGF is not a tacho signal, it is feedback signal to ECU so it knows coil has fired. It is not a square wave.
Postby MAGN1T » Sun May 09, 2010 1:16 am
So what would you do then?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby sergei » Sun May 09, 2010 1:23 am
MAGN1T wrote:So what would you do then?
Steve
obviously he is running some aftermarket ECU to drive coils, so get that to drive tacho.
Postby ATAl » Sun May 09, 2010 11:29 am
Yip, running a link g4 so am going to use an aux out as the tacho signal.
ATAl
