Can Mags be made wider?
Postby Barark » Sat May 08, 2010 11:32 am
Mr Revhead wrote:So is my lunch, but it still gets your attention when I stick it in your face
lol
Barark
Postby mr30%jr » Sat May 08, 2010 12:01 pm
mr30%jr
Postby Brick » Sat May 08, 2010 12:32 pm
Seeing threads like this just makes me realise how fortunate i am :D
Brick
I know Kung Fu
Postby MILFY » Sat May 08, 2010 12:54 pm
I'm think 7" is definately going to be wide enough, but is 15" going to be too small?
MILFY
Postby Dell'Orto » Sat May 08, 2010 12:57 pm
Depends on the look you're going for...15's can look good, and obviously weigh less. 17's and up will fill the guards more, but can make the car look like a rollerskate if its not lowered suitably.
Postby Mr Revhead » Sat May 08, 2010 12:57 pm
depends if you're an elephant or not
What tyres are you wanting to run? This is a track car isn't it?
You need to think about what tyres are available if thats the case
Postby Barark » Sat May 08, 2010 12:59 pm
Where would i go to find info on track wheels?
Barark
Postby mr30%jr » Sat May 08, 2010 2:39 pm
MILFY wrote:I'm think 7" is definately going to be wide enough, but is 15" going to be too small?
yupppp youl want 19X6
why in gods name would we listen to you..... :roll:
mr30%jr
Postby holden_fan2005 » Sat May 08, 2010 2:46 pm
Widened steel wheels aren't new at all. The old man tells stories how they would cut a rim on a lathe and weld a 2" or 4" steel band in the rim.
Go talk to your local engineers :)
holden_fan2005
Postby mr30%jr » Sat May 08, 2010 2:50 pm
Barark wrote:Where would i go to find info on track wheels?
you wont find any youve just been told.
15X7 is good there are alot of good tyre combos around 205X15 50s. and that 16 is a bitch
14 is dum too slopy
mr30%jr
Postby Barark » Sat May 08, 2010 2:51 pm
thank you for your help
Barark
Postby MILFY » Sat May 08, 2010 5:50 pm
Dell'Orto wrote:Depends on the look you're going for...15's can look good, and obviously weigh less. 17's and up will fill the guards more, but can make the car look like a rollerskate if its not lowered suitably.
Yes... 17" and upwards do look ridiculous... I totally agree... jus been looking at Barack's car and 15 are going to be more than adequate :wink:
MILFY
Postby MILFY » Sat May 08, 2010 5:51 pm
don't recall saying 19"
MILFY
Postby MILFY » Sat May 08, 2010 5:53 pm
holden_fan2005 wrote:Widened steel wheels aren't new at all. The old man tells stories how they would cut a rim on a lathe and weld a 2" or 4" steel band in the rim.
We know its not new... but it is a forgotten art... and it looks awesome!
MILFY
Postby mjrstar » Sat May 08, 2010 6:26 pm
there is a rule with wheels the width cannot be less that 1/2 the diameter. ie:
15x7.5
16x8
17x8.5
18x9
Stick to this formula and you will be right
15x7 will result in a fail.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby nz_climber » Sat May 08, 2010 8:07 pm
Don't know where you got that rule from, most 15inch wheels are 6.5inch and 7inch wide, even down to 6inch for some of the lighter wheels.
In 15inch, most Rspec (semi slick) tyres come in 205/50/R15 or 195/50/R15. They tend to be the most popular, and depending on the brand 6.5inch and 7inch is the perfered width for a 15inch wheel, check out the manufactures website (bridgestone, toyo, yoko etc)
nz_climber
Postby mjrstar » Sat May 08, 2010 8:37 pm
oh..
don't take me too literally it is an unwritten rule of mine to ensure cool-factor. 8)
i run a 205-50-15 on a 15x8 which makes things look like this:
or this if you look end on
which is just fine by me.. The 02g is a pretty generous 205 ( near on 215mm tread width)
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby frost » Sat May 08, 2010 9:00 pm
deaf_rattle wrote:Image
wicked
very bad idea,
im sure we covered this topic one year ago, quite a few pages of info too,
basically cast wheels like this one should not be widened because there prone to stress cracking, and the alloy is too old to weld and is more porous then the new alloy being introduced causing the surrounding metal to stress and crack over time,
Postby shihad » Sat May 08, 2010 9:56 pm
mjrstar wrote:oh..
:lol: maybe its the half bottle of red but you made my day.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby nz_climber » Sat May 08, 2010 10:49 pm
Sweet, no worries about that, thought there might have been serious rule that nobody told me (or wheel makers) :P Yeah dunlops are generous in width same with alot of other semi slicks, some semi slicks 195's are wider than street tyres in 205's.
nz_climber
Users browsing this forum: Google [Bot] and 1 guest
